Re: Mopar stage 6 heads
[Re: BloFish]
#2209436
12/07/16 05:24 PM
12/07/16 05:24 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I have run this engine straight out of the crate with no significant inspection since the day I got it back in 1997. I have had no issues other than slow et's I don't think Cummins Recon was building them in 97 so you are probably safe. Are the heads posted above the heads that were on that engine?
[Re: fast68plymouth]
#2209437
12/07/16 05:30 PM
12/07/16 05:30 PM
JohnRR
[quote]
440Pursuit....... The credit for that intake port layout goes to Mike Doty. He's the one that came up with that. From memory, I think those heads flowed around 340. The best non-Chapman stage 6's I've seen. About 700hp from a 470 with a flat tappet cam on pump gas. Dwayne beat me to it ... Brianwo LOANED the heads for the build , I bought them from him after the contest was over and Sold them to Jim along with the modified intake and the Erson rockers that were set up on them. Mike Doty did an outstanding job designing the port on that head within the constraints of the rules, which Parkhurst was nice enough to change mid contest after the spring pockets were raised so a longer valve could be used ... the way they should have been originally ... who is the rocket scientist at MP that thought it was a great idea to use stock length iron head valves in that head ???
[Re: fast414]
#2209445
12/07/16 05:46 PM
12/07/16 05:46 PM
Posts: 16,536 On the run…
BloFish
On the run…
The boxes are all ready packed up and on there way to UPS. I did send the boxes with the heads.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: fast414]
#2209546
12/07/16 08:33 PM
12/07/16 08:33 PM
Posts: 5,080 organ
maximum entropy
organ
aah, the glorious stage 6. the mothership wanted stock length valves, and stock rockers, hence the ridiculously deep valve spring pockets and push rod intrusions. i was on a back order list for a set of those when they first came out, but the two years i was on the list gave me ample opportunity to investigate their foibles. i would (and did) pass.
[Re: BloFish]
#2209717
12/07/16 11:53 PM
12/07/16 11:53 PM
BradH
These will be going on a Mopar 575 hp, stage 6 head crate engine... What intake manifold? I suspect I know the answer already, though.
[Re: JohnRR]
#2209720
12/07/16 11:57 PM
12/07/16 11:57 PM
BradH
[quote=fast68plymouth]
... Brianwo LOANED the heads for the build... Yeah, right after he bought the bare heads from me. They were an oddball deal, too, since they had nice CNC'd chambers, but otherwise stock as-cast ports.
[Re: BradH]
#2209817
12/08/16 01:46 AM
12/08/16 01:46 AM
BloFish
On the run…
These will be going on a Mopar 575 hp, stage 6 head crate engine... What intake manifold? I suspect I know the answer already, though. M1 single plane.
[Re: JohnRR]
#2209819
12/08/16 01:48 AM
12/08/16 01:48 AM
BloFish
On the run…
I have run this engine straight out of the crate with no significant inspection since the day I got it back in 1997. I have had no issues other than slow et's I don't think Cummins Recon was building them in 97 so you are probably safe. Are the heads posted above the heads that were on that engine? No, they were ordered shortly after getting the engine. I put them on a shelf and never touched them.
[Re: fast414]
#2210033
12/08/16 01:37 PM
12/08/16 01:37 PM
fast68plymouth
So. Burlington, Vt.
Slightly off topic, but has anyone ever seen an independant dyno test of a unmolested 575hp crate engine? Depending on how the heads were prepped.... It seems like that could be a stretch. I would think "some" amount of bowl work would have had to be done to get that combo to that power level.
[Re: BloFish]
#2210044
12/08/16 01:58 PM
12/08/16 01:58 PM
BradH
These will be going on a Mopar 575 hp, stage 6 head crate engine... What intake manifold? I suspect I know the answer already, though. M1 single plane. The Stage VI-specific full-width (no valley cover required) 4150 flange version? If so, just a "heads up" -- no pun intended -- that is not a very good intake as cast from what I've seen.
#2210045
12/08/16 01:59 PM
12/08/16 01:59 PM
BradH
Slightly off topic, but has anyone ever seen an independant dyno test of a unmolested 575hp crate engine? Depending on how the heads were prepped.... It seems like that could be a stretch. I would think "some" amount of bowl work would have had to be done to get that combo to that power level. Not that I recall, only the iron-head version that was rated quite a bit lower.
[Re: fast414]
#2210050
12/08/16 02:21 PM
12/08/16 02:21 PM
fast68plymouth
So. Burlington, Vt.
Here something I find interesting about the specs for the 505hp and 575hp motors. The 505 motor is listed as 9:1 with flat tops, the 575 as 11.25:1 with flat tops. The service replacement head for the 575 motor is listed as 90cc's. At zero deck with a .040 head gasket and a 5cc piston, add 1cc for the area above the rings...... I get 10.66:1.
How much bigger does the stage v iron head have to be, and how far down the bore are the pistons to get that down to 9:1? I guess I'm kinda surprised that they would have had different pistons being used in those two packages.
What kind of numbers did you see from the 505 test?
I just noticed a little footnote at the bottom of the specs for the 575hp motor.
"First quarter 2001 availability" and "Requires a minimum of 110 octane racing fuel"
#2210084
12/08/16 03:09 PM
12/08/16 03:09 PM
BradH
What kind of numbers did you see from the 505 test? What I remember is the article was in either Hot Rod or Car Craft and that it was done at Dick Landy's shop. I don't recall it making much different than advertised, and considering DLI's connection w/ Mopar Performance, wouldn't expect it to for the purpose of a magazine article. Anybody else recall that there were two (2) different versions of the MP 500 crate engines offered w/ Stage VI heads? The first one was rated at 545 HP, then IIRC they switched from 1.5 to 1.6 rockers and re-rated it to 575 HP. The rumor I heard years ago was that one of these "575 HP" engines was dynoed OOB at Ray Barton's shop... and wasn't even close to the advertised #.
[Re: fast414]
#2210158
12/08/16 05:34 PM
12/08/16 05:34 PM
fast68plymouth
So. Burlington, Vt.
If the heads used on the crate motors were similar to the ones you could buy over the counter, without some reworking, I don't see how they could have been making 575hp out of that combo.
Would have been "fun" to test one right ootb......eer.....oot-crate.
[Re: BradH]
#2210424
12/09/16 12:34 AM
12/09/16 12:34 AM
BloFish
On the run…
These will be going on a Mopar 575 hp, stage 6 head crate engine... What intake manifold? I suspect I know the answer already, though. M1 single plane. The Stage VI-specific full-width (no valley cover required) 4150 flange version? If so, just a "heads up" -- no pun intended -- that is not a very good intake as cast from what I've seen. That's the one. Is there something better?
[Re: fast414]
#2210566
12/09/16 11:02 AM
12/09/16 11:02 AM
BloFish
On the run…
Sorry, I misunderstood, read the question. That is the intake that came with the engine.
