Re: Custom cam grind ?
[Re: HOTHEMI]
#2208585
12/06/16 03:55 AM
12/06/16 03:55 AM
Posts: 4,457 Washington
madscientist
Washington
Basically , yes. I have a 524/507 MP Hyd cam now, would like to get something close in a solid grind .Street/Strip Hemi Just put solid lifters on that cam and lash it at .002 and run it.
[Re: HOTHEMI]
#2208678
12/06/16 01:21 PM
12/06/16 01:21 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Imo...........Not really a good option if this is for a street car.
[Re: HOTHEMI]
#2208687
12/06/16 01:36 PM
12/06/16 01:36 PM
madscientist
Washington
Can this be done ? I know the pushrods are different length. Has anyone here done it before ? Thanks. It's done all the time. You can put solid rollers on a hydraulic core. It's not even a new thing. Been done for years. It will make more HP, RPM higher and be just as reliable. Screw hydraulic lifters. All of them. Lash it at .002 and go.
[Re: madscientist]
#2208707
12/06/16 02:09 PM
12/06/16 02:09 PM
Posts: 19,488 north of coder
moparx
Can this be done ? I know the pushrods are different length. Has anyone here done it before ? Thanks. It's done all the time. You can put solid rollers on a hydraulic core. It's not even a new thing. Been done for years. It will make more HP, RPM higher and be just as reliable. Screw hydraulic lifters. All of them. Lash it at .002 and go. does the cam have to be a roller core to do this ?
[Re: moparx]
#2208860
12/06/16 06:27 PM
12/06/16 06:27 PM
madscientist
Washington
Can this be done ? I know the pushrods are different length. Has anyone here done it before ? Thanks. It's done all the time. You can put solid rollers on a hydraulic core. It's not even a new thing. Been done for years. It will make more HP, RPM higher and be just as reliable. Screw hydraulic lifters. All of them. Lash it at .002 and go. does the cam have to be a roller core to do this ? Hydraulic roller core, solid lifter.
[Re: HOTHEMI]
#2209019
12/06/16 11:12 PM
12/06/16 11:12 PM
Posts: 4,209 New York
polyspheric
New York
Ask your cam guy about the relative accel of hyd vs solid ramps, but hold the phone away from your ear because he's going to yell at you.
Boffin Emeritus
[Re: HOTHEMI]
#2209033
12/06/16 11:24 PM
12/06/16 11:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm confused here..this a hydraulic flat tappet cam ,not a hydraulic roller cam , maybe I can just have a cam ground to the same specs as a solid lifter type . You could get a roller with the same specs but why.. you could get something a bit better... and what was said before no you cant put a roller lifter on a hyd flat tappet cam
[Re: HOTHEMI]
#2209113
12/07/16 01:20 AM
12/07/16 01:20 AM
madscientist
Washington
I'm confused here..this a hydraulic flat tappet cam ,not a hydraulic roller cam , maybe I can just have a cam ground to the same specs as a solid lifter type . Ahhh [censored], my bad, I thought you said you had a hydraulic ROLLER cam. Need to brush up on my reading comprehension.
[Re: HOTHEMI]
#2209114
12/07/16 01:22 AM
12/07/16 01:22 AM
madscientist
Washington
I went back a reread the first post. I have no idea where I got the roller cam idea from.
So no, don't put a solid flat tappet on a hydraulic grind.
But you can use solid ROLLER lifters on a hydraulic ROLLER cam.
[Re: HOTHEMI]
#2209365
12/07/16 03:18 PM
12/07/16 03:18 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Just talk to Dwayne Porter (fast68plymouth) who already responded on here. He is one of the best cam person's out there and can grind a custom cam for you. I used a solid flat tappet that I got from Dwayne as I told him my car was a pump gas street car and I wanted a solid cam that had a nice kinda lumpy idle and made good power and had to keep my cyl pressure pump gas friendly. He speced the whole cam as he speced the lift , duration , LSA and gave me the recomended installed centerline. He had the cam ground for me to the specs he recomended and it has been working great for over 5 years in my eng. I have been a tech all my life and know a good bit about cams but I am no pro like Dwayne is when it comes to cams. He does it all the time everyday and every car I see with his cams in them always run great. You cant go wrong by calling and talking to Dwayne as you can call him at 802-951-1955. Good luck with it , Ron
