Custom cam grind ? #2208430
12/05/16 11:25 PM
12/05/16 11:25 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
Can a hydraulic cam profile ( specs) be converted over to a solid cam grind ?
Re: Custom cam grind ? [Re: HOTHEMI] #2208441
12/05/16 11:39 PM
12/05/16 11:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sure. It would have to be ground just a little bigger to make up for the amount of lift and duration lost with the lash of a solid cam vs hyd. Is that what your asking??
Re: Custom cam grind ? [Re: Sport440] #2208448
12/05/16 11:46 PM
12/05/16 11:46 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
Basically , yes. I have a 524/507 MP Hyd cam now, would like to get something close in a solid grind .Street/Strip Hemi
Re: Custom cam grind ? [Re: HOTHEMI] #2208540
12/06/16 02:24 AM
12/06/16 02:24 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
call Hughes Engines---you wont be disappointed.
Re: Custom cam grind ? [Re: HOTHEMI] #2208585
12/06/16 03:55 AM
12/06/16 03:55 AM
Washington
madscientist Offline
Washington
Just put solid lifters on that cam and lash it at .002 and run it.
Re: Custom cam grind ? [Re: madscientist] #2208613
12/06/16 08:37 AM
12/06/16 08:37 AM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
Can this be done ? I know the pushrods are different length. Has anyone here done it before ? Thanks.
Re: Custom cam grind ? [Re: HOTHEMI] #2208678
12/06/16 01:21 PM
12/06/16 01:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Imo...........Not really a good option if this is for a street car.
Re: Custom cam grind ? [Re: HOTHEMI] #2208687
12/06/16 01:36 PM
12/06/16 01:36 PM
Washington
Washington
It's done all the time. You can put solid rollers on a hydraulic core. It's not even a new thing. Been done for years. It will make more HP, RPM higher and be just as reliable.
Screw hydraulic lifters. All of them.
Lash it at .002 and go.
Re: Custom cam grind ? [Re: madscientist] #2208707
12/06/16 02:09 PM
12/06/16 02:09 PM
moparx Offline
moparx  Offline
does the cam have to be a roller core to do this ?
beer
Re: Custom cam grind ? [Re: moparx] #2208860
12/06/16 06:27 PM
12/06/16 06:27 PM
Washington
Washington
beer
Hydraulic roller core, solid lifter.
Re: Custom cam grind ? [Re: HOTHEMI] #2209017
12/06/16 11:09 PM
12/06/16 11:09 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
I'm confused here..this a hydraulic flat tappet cam ,not a hydraulic roller cam , maybe I can just have a cam ground to the same specs as a solid lifter type .
Re: Custom cam grind ? [Re: HOTHEMI] #2209019
12/06/16 11:12 PM
12/06/16 11:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Ask your cam guy about the relative accel of hyd vs solid ramps, but hold the phone away from your ear because he's going to yell at you.
Boffin Emeritus
Re: Custom cam grind ? [Re: HOTHEMI] #2209033
12/06/16 11:24 PM
12/06/16 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could get a roller with the same specs but why.. you
could get something a bit better... and what was said before
no you cant put a roller lifter on a hyd flat tappet cam
wave
Re: Custom cam grind ? [Re: HOTHEMI] #2209113
12/07/16 01:20 AM
12/07/16 01:20 AM
Washington
Washington
Ahhh [censored], my bad, I thought you said you had a hydraulic ROLLER cam.
Need to brush up on my reading comprehension.
Re: Custom cam grind ? [Re: HOTHEMI] #2209114
12/07/16 01:22 AM
12/07/16 01:22 AM
Washington
Washington
I went back a reread the first post. I have no idea where I got the roller cam idea from.
So no, don't put a solid flat tappet on a hydraulic grind.
But you can use solid ROLLER lifters on a hydraulic ROLLER cam.
Re: Custom cam grind ? [Re: HOTHEMI] #2209131
12/07/16 02:14 AM
12/07/16 02:14 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
solid lifter flat tappet cams with have a more aggressive lift profile than an equivalent hydraulic cam. this will add more power down low and add a few rpm to the top end. you can get a cam ground similar to what you have now, but I bet there are better cams already ground, you just have to pick the right one.
your cam specs are pretty common, but you don't say what you want to do with the car or why you want a solid cam? maybe a better hydraulic is in order and save yourself some valve lashing.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Custom cam grind ? [Re: HOTHEMI] #2209365
12/07/16 03:18 PM
12/07/16 03:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just talk to Dwayne Porter (fast68plymouth) who already responded on here. He is one of the best cam person's out there and can grind a custom cam for you. I used a solid flat tappet that I got from Dwayne as I told him my car was a pump gas street car and I wanted a solid cam that had a nice kinda lumpy idle and made good power and had to keep my cyl pressure pump gas friendly. He speced the whole cam as he speced the lift , duration , LSA and gave me the recomended installed centerline. He had the cam ground for me to the specs he recomended and it has been working great for over 5 years in my eng. I have been a tech all my life and know a good bit about cams but I am no pro like Dwayne is when it comes to cams. He does it all the time everyday and every car I see with his cams in them always run great. You cant go wrong by calling and talking to Dwayne as you can call him at 802-951-1955. Good luck with it , Ron
