Page 2 of 3 1 2 3
Re: Pro Street pickups? [Re: scratchnfotraction] #2204908
11/30/16 12:57 AM
11/30/16 12:57 AM
scratchnfotraction Offline
here's a shot of my 85 stepside tubbed with the a-body 8 3/4
Re: Pro Street pickups? [Re: scratchnfotraction] #2204914
11/30/16 01:03 AM
11/30/16 01:03 AM
here's a couple shots of a stepside I saved a while back.
copper and black stepside.jpgcopper and black stepside#2.jpg65 truck with fattys#2.jpg
Re: Pro Street pickups? [Re: scratchnfotraction] #2204921
11/30/16 01:11 AM
11/30/16 01:11 AM
here's a way moparts member ferlin was able to move leafs in line with frame rails. IIRC he had 14" wide rims and a 21,50 tire
ferlins inline front spring hanger.jpgferlins rear shackle.jpgferlins rear shot.jpgferlins truck side shot.jpg
Re: Pro Street pickups? [Re: scratchnfotraction] #2204924
11/30/16 01:14 AM
11/30/16 01:14 AM
flight727 with a 440/a-body 8 3/4 set up. used some square stock bolted to frame to mount the a-body shackle hanger.
flight727 rear shackle bracket with abody shackles.jpgflight727 rear shot.jpgflight727 bed shot.jpg
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2205141
11/30/16 11:35 AM
11/30/16 11:35 AM
IIRC, member kenworth Goose moved the leafs to the inside frame rails by boxing the frame and moving the mounts left to right on inside of frame rails. then narrowed a 8 1/4 rear axle for 18.5 or 21.5 M/Ts
I didn't get any of those pics. but it was a cool way of narrowing the 8 1/4 housing at home with some all thred rod and torch/welder.
a few here said he could not do it...but he did. AND it worked! IIRC even Moser looked at it when they cut/resplined the stock axles and said well done.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2208008
12/05/16 05:35 AM
12/05/16 05:35 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Hey Scratch,
That's what i did too, on my old 77. Worked out slick. [img:center][/img]
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2208125
12/05/16 02:59 PM
12/05/16 02:59 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
way back in '87
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2208482
12/06/16 12:52 AM
12/06/16 12:52 AM
Canada
CrAzYMoPaRGuY Offline OP
Canada
This is what we THINK we've found out..... lol
79" total rear body width. I can get away with 76" outside of tire to outside of tire.
With a 295/65/15 on a 15x10 rim with 3 1/2" backspace we figure we need a rear end 59 1/4" overall width.
Springs are 43 1/2" center to center apart.
A 1966/1967 B body rear end is 59 1/2" overall width and 44" spring centers......
Hmmmmmm
I'll just have to split the inner can on the bed and move the inner to the next raised bed section, about 3 1/2" inches inboard, toss a strip in and make it pretty and nobody should be able to tell we monkeyed around....
An 8 3/4 is .65" longer center of axles to center of u joint, and my driveshaft looks a wee bit short anyways, the swap will probably HELP?! lol
CrAzYMoPaRGuY
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2208696
12/06/16 01:52 PM
12/06/16 01:52 PM
the 72-74 truck 8 3/4 housing is 59" outside to outside bearing cup.
same as 73-74 c-body 8 3/4 housing.
I have a 67 c-body Polara 8 3/4 housing with a 55.5" housing 46" perch center and a set of 30" axles. it may be close to the 59 1/4 over all width your measurements come up with.
I will throw a tape on a set of stock 8 3/4 truck axles in the housing for a over all width measurement.
I wager the 67 c-body housing is going to be real close. I came up with a 325/15/15 on a 10x15 with 3.5 bs when I did my measuring. BUT I did measure for the B-body housing and was very close to same measurements = I already have the 67 c-body housing,
if you look at pics of my tubs you can see I moved over to the floor/frame bracket. tubs flush with outside frame rails. did my stepside over to the floor/frame mount same way.
that would be best IMHO.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2209023
12/06/16 11:16 PM
12/06/16 11:16 PM
ky.
K
kenworth_goose Offline
K
ky.
here is a picture of the one I did.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2209026
12/06/16 11:18 PM
12/06/16 11:18 PM
ky.
K
K
ky.
And the truck. 33x21.50"s with No frame mods. Moved the spring to the inside of the frame.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2209070
12/07/16 12:14 AM
12/07/16 12:14 AM
Pittsburgh,PA
RTSrunner Online content
RTSrunner  Online Content
Pittsburgh,PA
How does it handle with the springs mounted inside the frame vs under it? I thought they were supposed to" have erratic handling characteristics" according to an old Mopar chassis book.Tire clearance looks amazing with stock rail placement!
Re: Pro Street pickups? [Re: scratchnfotraction] #2209091
12/07/16 12:38 AM
12/07/16 12:38 AM
Canada
Canada
I think the inner factory tub will be going to the frame rail for sure, just in case I try something bigger.... we have spare 21.50/33/15s..... lol You never know...
Moving springs aint too hard for us.
I was planning on 325/50/15s on 15x10 with a 3.5" backspace! But I came up with 66/67 B body rear. I have a 68 C body 8 3/4 available next weekend, we are parting out a 1968 300.....
CrAzYMoPaRGuY
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2209196
12/07/16 10:03 AM
12/07/16 10:03 AM
that 68 c-body is same width as a stock truck rearend.
I have seen/used a 10x15 rim with 7.5 bs and just split the tubs with a fill panel.
does not have the deep dish look to the rim but fits them in there nicely with no work other than tubs.
Moser can cut them down cheaply enough, about 40 bone to and from and my last cut down was 65 bones.
I am sending in another to cut down to A-body specs with large offset axles/brakes.
325/50/15 = 29x15x15 M/T sportsman/sportsman pro/sportsman SR radials
same as the old N50-15
thanks Kenworth Goose, love to see that truck. that's a lot of tire.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2209373
12/07/16 03:49 PM
12/07/16 03:49 PM
ky.
K
K
ky.
My truck handled great with the springs on the inside of the frame. Wish I still had it.
Re: Pro Street pickups? [Re: kenworth_goose] #2209784
12/08/16 01:12 AM
12/08/16 01:12 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
my 65 I also moved springs to inside of frame
Re: Pro Street pickups? [Re: kenworth_goose] #2209922
12/08/16 09:08 AM
12/08/16 09:08 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
^^^Like this truck^^^ thumbs
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2211802
12/11/16 01:49 PM
12/11/16 01:49 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Here is my pro street, drag 76 truck
Re: Pro Street pickups? [Re: kenworth_goose] #2212022
12/11/16 07:51 PM
12/11/16 07:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
And the truck.
All the trucks in this thread are outstanding,
but that truck is Sa-Weet!. beer
Nice to see some one using a torch in this day and age. up
I have mechanical Aptitude.
I can screw up anything.
Re: Pro Street pickups? [Re: CrAzYMoPaRGuY] #2213261
12/13/16 01:03 PM
12/13/16 01:03 PM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
I dont think my 1964 D100 is a Pro street, but I did modify the box with big tubs to fit 16 inch tires. The springs are in stock location on outside of the frame.
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Page 2 of 3 1 2 3
