Re: Mopar stage 6 heads
[Re: fast414]
#2208374
12/05/16 10:09 PM
12/05/16 10:09 PM
Posts: 16,542 On the run…
BloFish
On the run…
Worth spending the dough?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: fast414]
#2208382
12/05/16 10:27 PM
12/05/16 10:27 PM
fast68plymouth
So. Burlington, Vt.
I guess that depends on how much you're willing to spend to get them ready to run, and what your expectations are from them.
If you're trying to make 700hp+, I'd say use something else. Depending on exactly what it would take to make those a ready to bolt on pair of heads, and you were looking to make under 700hp...... Then they might be worth it.
At a minimum they need $500-600 worth of parts, someone to measure everything up, check the valve job, more than likely need surfacing, etc...... It's an easy $1000 bill if there are no major issues. Without being able to evaluate the short turn work, I'd say those would probably flow in the 285-300cfm range as they are..... If the short turn is decent. You could easily spend another $200-300 detailing the port work a bit.
The chambers look kinda deep........ Wouldn't surprise me a bit if they were in the 90cc range. Might want to grab a head gasket and set it on there and see if there is an overhang issue.
[Re: fast414]
#2208390
12/05/16 10:38 PM
12/05/16 10:38 PM
BloFish
On the run…
Sounds reasonable. I'll send you a pm.
[Re: fast414]
#2208739
12/06/16 02:43 PM
12/06/16 02:43 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Dwayne is giving you good advice , I'll add one thing I learned ...
Put them BOTH on a block before you do anything , make sure they drop on the dowel pins AND that you can get ALL the head bolts in. I had a set of the 383/440 street castings ... Stage 6 core based ... one head was ok , the other head dropped on the dowel pins and only 2 head bolts would go in, the dowel pin holes were drilled at an angle.
[Re: JohnRR]
#2208760
12/06/16 03:16 PM
12/06/16 03:16 PM
dogdays
Those heads would have maximum value on a 600hp engine built on a 400 block. The chambers do appear deep so let's assume they are indeed 90cc. They would give a comp ratio between 10.0 and 10.5:1 using a zero deck flattop piston and 0.039" gasket. Probably run on midgrade. The combustion chamber general shape isn't bad. Putting them on a 400 block lets you use a 440 intake and that opens up more choices, and I believe better choices. Oil collecting in the extra-deep valve spring pockets could be drained off with a hand drill or a die grinder with a cutoff wheel. Slots just have to work, they don't have to be precise. That's my R.
[Re: fast414]
#2208765
12/06/16 03:20 PM
12/06/16 03:20 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I have an interesting set I got from 440Jim.
Dwayne may remember them as they were a joint effort by Dwayne, Dan Costello, and Ryan J.
Real Cool Epoxied heart shaped runners and relocated ports to MW/Indy. Maybe Dwayne recalls the flow #'s. I havent used them yet.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: fast414]
#2208801
12/06/16 04:55 PM
12/06/16 04:55 PM
BloFish
On the run…
These will be going on a Mopar 575 hp, stage 6 head crate engine, that has been untouched, sans a set of Harlan sharp 1.6 rockers. It should be a bolt on application when done. Just looking to better my flow.
[Re: BloFish]
#2208880
12/06/16 06:55 PM
12/06/16 06:55 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I love it when guys say stage 6 heads will only put out 600 horsepower. I'll have to tell my Friend that run 9's in his street legal Duster. LOL Trust me, in the right hands they will surpass that number.
[Re: fast68plymouth]
#2208922
12/06/16 08:23 PM
12/06/16 08:23 PM
BradH
I wonder who they had do the CNC work. Same here. I was trying to recall if MP ever listed a CNC-ported Stage VI prior to the Chapman offerings, but I simply don't know. CNC'd or not, they still look like they could benefit from a good bit of in the ports. Lots of drop-outs where the cutter isn't even close to the casting, so it must have been a pretty conservative program, too.
[Re: BloFish]
#2208924
12/06/16 08:25 PM
12/06/16 08:25 PM
BradH
These will be going on a Mopar 575 hp, stage 6 head crate engine, that has been untouched, sans a set of Harlan sharp 1.6 rockers. It should be a bolt on application when done. Just looking to better my flow. You're not planning on running that crate engine w/o tearing it down & inspecting everything, are you? Some of the MP crate engines were real P's of S that need significant fixing before they should have ever been started. Very scary...
[Re: fast414]
#2209298
12/07/16 01:24 PM
12/07/16 01:24 PM
fast68plymouth
So. Burlington, Vt.
I have had no issues other than slow et's I'm sure many a Mopar 575hp crate motor owner would be happy with an 11.27 @ 118 time slip(unless it was in a 2200lb car). Depending on the overall combo and where you're racing, that doesn't seem that bad at all to me. Jay..... Sounds like everyone has gotten their money's worth out of that thing!! 440Pursuit....... The credit for that intake port layout goes to Mike Doty. He's the one that came up with that. From memory, I think those heads flowed around 340. The best non-Chapman stage 6's I've seen. About 700hp from a 470 with a flat tappet cam on pump gas.
[Re: fast414]
#2209310
12/07/16 01:41 PM
12/07/16 01:41 PM
fast68plymouth
So. Burlington, Vt.
In my 2001 catalog I show a few different options for ported stage 6's. P4876186- assy with 2.14/1.81 valves P4876187- assy with 2.18/1.81 valves
They show 2 different CNC ported heads "machined for 2.18 intake and 1.81 exhaust" valves, but then the two different part numbers are listed as either: P4876382- flat tappet cam(lifts up to .650) P4876383- roller tappet cam(lifts over .600) With a foot note stating that MW heads require offset pushrods.
If I had to guess....... I'd say the description of those two part numbers is incorrect. I think they are bare heads and that one was std port and the other MW port. (I realize these two numbers at one point were used for the Chapman heads, but I didn't think had arrived on the scene yet in 2001)
There is also number P4876991, which is listed as a service replacement assy for the 575hp crate motor.......90cc chamber.
And P5007484- "hi ratio assy, 78cc chamber"
Blofish, what part number is on the box for the heads you have?
#2209419
12/07/16 04:55 PM
12/07/16 04:55 PM
BradH
If I had to guess....... I'd say the description of those two part numbers is incorrect. I think they are bare heads and that one was std port and the other MW port. (I realize these two numbers at one point were used for the Chapman heads, but I didn't think had arrived on the scene yet in 2001) Right; They were released in 2003... just in time for Steve Dulcich to get a set for that year's Engine Masters event ( after the Moparts.com team had been told they wouldn't be legal, IIRC). Oh, I had (have?) the flow #s for the Moparts EMC Stage VI heads... somewhere. Best as I can recall, they peaked about 345 on the intakes, pretty much what you said.
[Re: pittsburghracer]
#2209434
12/07/16 05:22 PM
12/07/16 05:22 PM
JohnRR
I love it when guys say stage 6 heads will only put out 600 horsepower. I'll have to tell my Friend that run 9's in his street legal Duster. LOL Trust me, in the right hands they will surpass that number. The 469" enginemasters entry made over 700hp, those heads had some interesting work done to them. If I remember right they flowed about 330cfm before Dwayne tweaked them after I sold them to Jim.
