Craigslist Score
#2207756
12/04/16 08:32 PM
12/04/16 08:32 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Scored a 2005 545RFE 5 speed automatic out of 2 wheel drive 5.7 Hemi Ram yesterday for $300, took 2 cans of degreaser and an hour with the pressure sprayer to get it clean. It came with dipstick and cooler. I will have it checked out and rebuilt if nessesary. It will go behind the 6.4 Hemi that's going into my 37 pickup
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Craigslist Score
[Re: AZ_A12_BEE]
#2208018
12/05/16 08:56 AM
12/05/16 08:56 AM
Posts: 1,513 AZ
Mike P
AZ
Way cool, nice score. Depending on how high you set the engine/trans you may have some floor modifications in your future.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Twostick]
#2208103
12/05/16 02:23 PM
12/05/16 02:23 PM
AZ_A12_BEE
Dreaming of the 808
Good score.
Couple of questions. What are you going to control it with?
Does a 4.7 have the same bolt pattern?
Kevin I'm calling Hotwire today to find out what I need ti control it, I'm not sure about the 4.7
37 Plymouth PU
[Re: Mike P]
#2208106
12/05/16 02:27 PM
12/05/16 02:27 PM
AZ_A12_BEE
Dreaming of the 808
Way cool, nice score. Depending on how high you set the engine/trans you may have some floor modifications in your future. Mike, I always assented that there would be some floor modifications, after all is said and done I plan on welding the floor and lower firewall together as one unit rather than bolt on as it is now
37 Plymouth PU
[Re: moparx]
#2208109
12/05/16 02:30 PM
12/05/16 02:30 PM
AZ_A12_BEE
Dreaming of the 808
good buy ! i'm guessing it is a good, running unit as is ? how many miles ? as it came with a dipstick, what year did the dipstick go away to where it takes the dealer to check the transmission fluid ? or is that a different transmission such as the six and eight speed units ? and as was already mentioned, what controller are you planning to use ? sorry for the many questions, but i really don't know much about these transmissions. I saw the truck it came out of, a 2005 Ram 1500 with 150K miles, I assume it to be a core but he swears it ran and drove perfectly, I will send ot out to a shop to be checked and rebuilt if needed before permanent install I'm calling Hotwire today to plan my wiring to control it and the motor
37 Plymouth PU
[Re: AZ_A12_BEE]
#2212491
12/12/16 02:14 PM
12/12/16 02:14 PM
Posts: 7,506 Az
Crizila
Az
Here's a little something to help you plumb that thing.
Fastest 300
