Re: A833OD ID. Need help
[Re: da50r]
#2205697
12/01/16 02:38 AM
12/01/16 02:38 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
Who ever told you that trans came from a car that the tranny would fit in a early A body told you wrong That tranny came from a pick up or full size van I have both types of the later model 833 O.D. trannys in the shop, the A body type is all aluminum, not with a cast steel tail shaft housing like that one with both mounts I do like that shifter better than the one I have on the same type tranny in my shop, do you want to sell the shifter? PM if so I'm putting my tranny like yours in a 1966 Dodge Coronet Deluxe B body two door sedan in back of a 440 motor Sorry for being the bearer of bad news
[Re: da50r]
#2205702
12/01/16 02:48 AM
12/01/16 02:48 AM
Posts: 2,628 Middle TN
da50r
Middle TN
I have not bought it. Guy sent me pics of it. Because I'm building a sub 300hp project the OD is attractive. Guess I need to move on. Is that confirmed that it's a truck trans then? Bummer. Lot of misinformation out there.
Ps - when you say early A body I think pre 67. I have a 73 Duster.
[Re: Stanton]
#2205891
12/01/16 03:21 PM
12/01/16 03:21 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Well if the price is right, grab it. Swapping a tailstock is no big deal and you have someone to buy the shifter. Bear in mind that there will likely be a problem with the front countershaft hole that will require boring the hole and bushing it BUT you'll likely encounter this problem with any OD box you come across - VERY common problem. Won't he have to change the main shaft to an Abody too? Are A/F body OD and std main shafts interchangeable? I think so, but not 100% sure. Won't an OD main shaft have the smaller output spline?
[Re: autoxcuda]
#2206094
12/01/16 09:40 PM
12/01/16 09:40 PM
Posts: 704 USA
rftroy
USA
Autoxcuda is correct. The mainshaft in the transmission the OP has pictured is the longer length, which means it will fit in an E or 70 and later B body. There were two different mainshaft lengths, one for A and F bodies, and one for B, E and C bodies. If you get an A Body OD4 mainshaft, you would need to disassemble the transmission and install all parts on the correct mainshaft. And you would also need the proper A/F tailshaft. Not at all worth the time and money to do that.
Keep looking.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
