roadunner fender interchange... #2204696
11/29/16 08:41 PM
11/29/16 08:41 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Hi Looking for a set of good steel fenders for my 1969 roadrunner..found some good and cheap ones from a 1970...will they fit at all?
Plaz
Re: roadunner fender interchange... [Re: plazomat] #2204702
11/29/16 08:47 PM
11/29/16 08:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mostly, yes; styling is different, and I'd bet they're different around the headlamp bezel as well.
Certainly any '69 Belvedere, Satellite, Sport Satellite, or GTX fender will interchange; trim holes will differ due to different nameplates & moldings.
'68s differ at the side markers, and I've heard at the radiator support, but never tried the swap so I can't confirm.
Re: roadunner fender interchange... [Re: plazomat] #2204708
11/29/16 08:51 PM
11/29/16 08:51 PM
plazomat Offline OP
plazomat  Offline OP
Thanks topside..I was wondering around headlight bezel as well...
the styling differences..trim holes are no biggy..
P
Re: roadunner fender interchange... [Re: plazomat] #2204754
11/29/16 10:03 PM
11/29/16 10:03 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Styling differences are quite obvious. 69 has an eyebrow over the fender opening that the 70 does not. If you find some good cheap 70 fenders, buy them, sell them for a profit and then buy some 69 ones. The 70 fenders should be more valuable than the 69 as no one makes aftermarket steel 70 fenders that I am aware of.
Re: roadunner fender interchange... [Re: plazomat] #2204926
11/30/16 01:16 AM
11/30/16 01:16 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
'68 will interchange a lot easier than '70's. If you bolt on '70's I doubt any other front end stuff will fit or look right - hood, grill, headlight buckets, valance.
Re: roadunner fender interchange... [Re: plazomat] #2205164
11/30/16 12:19 PM
11/30/16 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
P
70 will bolt on to the front of the car and line up with the door contour, that is where the similarity ends.
As noted a 68 fender is easier to make work , all you need to do is change the marker light hole, add in the piece that the headlight bezel screws to and add the top mounting point that attaches the fender to the upper radiator cross bar.
Re: roadunner fender interchange... [Re: plazomat] #2205447
11/30/16 08:27 PM
11/30/16 08:27 PM
plazomat Offline OP
plazomat  Offline OP
Thanks a bunch guys....I will pass on these fenders and keep my eye out...
Plaz
Re: roadunner fender interchange... [Re: plazomat] #2205741
12/01/16 08:11 AM
12/01/16 08:11 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It has been a while, but I don't believe the 68 and 69 are a true exchange, I think the flanges bolt up differently by the core support.
Re: roadunner fender interchange... [Re: sthemi] #2205760
12/01/16 10:59 AM
12/01/16 10:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can put a 68 on the 69 core support easily , the 69 on a 68 core support requires mods , it will not bolt on without at least removing a bracket that goes across the top of the radiator cross bar.
For 68 the hood bumper is on the core support, in 69 it is on a bracket that is attached to the fender in the same spot.
Re: roadunner fender interchange... [Re: sthemi] #2206790
12/03/16 02:00 AM
12/03/16 02:00 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Pretty much correct. 1969 is '69 only - 2 door - Sattelite, Belvidere, RR, GTX. Back when I was selling sheetmetal in the 80's & early 90's, '69 RR fenders were the one year only. Definitely NO on Coronet fenders too!
Re: roadunner fender interchange... [Re: plazomat] #2206875
12/03/16 10:50 AM
12/03/16 10:50 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
I have some rust free 69 fenders kinda beat up I was going to use to save my 68s. The park area is different, headlight bucket has an extra bracket to mount the grille and there is a bracket to attach to rad support the 68 doesn't have. 70s are smooth and don't have the upper reveal line the 8s and 9s do...I'd swap a 9 for an 8 to save a couple days of welding
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: roadunner fender interchange... [Re: plazomat] #2207069
12/03/16 06:14 PM
12/03/16 06:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Every year RR fender is different 68 69 70
Re: roadunner fender interchange... [Re: Sunroofcuda] #2207748
12/04/16 07:52 PM
12/04/16 07:52 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Also, 2dr. or 4dr. = same.
