slightly built 383 likes lots of timing?? #2202304
11/25/16 01:34 PM
11/25/16 01:34 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I was helping my pops out yesterday with his 383.
Pretty basic build-
383 .30 over
906 heads, bigger valves, cleaned up ports
small tube headers
edelbrock intake- 750 holley DP carb
lumpy cam- i dont remember the specs but i had called comp and talked to them and they suggested this cam for this engine.
9.5 to one compression.
once it is warmed up and idling at about 1100 if i hit the throttle it will backfire out the carb with the initial timing set at 12-15*
if i change it to about 20* the idle drops a little and smooths out and does not have that hesitation but then i have mid 40's total at 2200+.
what is that about? Is this okay?
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202307
11/25/16 01:39 PM
11/25/16 01:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Reduce the mechanical advance in the distributor. If it's an old style MP performance or factory you will have to weld the slots up. Newer style MP or after market usually have bushings or an adjustable plate. It may even like more than 20 initial. Just limit the total.
Doug
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202310
11/25/16 01:41 PM
11/25/16 01:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think 20 is fine but you might have to limit your total timing now but you wont know until you check it.
Gus beer
Treed by Doug laugh2
64 Plymouth Savoy
Dana 60
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202405
11/25/16 04:05 PM
11/25/16 04:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
Did you verify TDC on the balancer and timing tab when assembling it ? If not maybe you should work scope twocents
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202433
11/25/16 04:49 PM
11/25/16 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a stock balancer it could have slipped some
giving you some bad numbers... or like Doug said..
curve the dist.. but with a bigger cam(lumpy) it will
want more base timing but still want about 36* total
wave
Re: slightly built 383 likes lots of timing?? [Re: MR_P_BODY] #2202571
11/25/16 08:57 PM
11/25/16 08:57 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have found that 20* initial works well in lots of engines. If you have an older MP non adjustable dist, get hold of FBO. They make a great timing plate that is easy to install. It allows you to set up your dist for both initial and limits the total. The plate has slots in it that acts as a stop on the weight travel .
It only costs $22 and when you order it, ask the owner how to set up your vacumn advance and you are set. I set up two distributors with them and they made a huge difference, being able to use the vac advance again really sharpened up the response and helped the mileage two. I highly recommend them.
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202573
11/25/16 09:04 PM
11/25/16 09:04 PM
The reason I asked about the timing marks accuracy is most BB Mopars won't backfire through the carb. at idle when you open the throttle quickly in neutral unless the initial idle timing is close to TDC or even retarded past TDC work scope I've also seen early model(pre 1966) balancers used on the 1966 and later motors with the later timing cover which ends up showing the TDC on that balancer to be about 15 degrees retarded on the later timing cover marks shruggy
Murphy loves messin with hot rodders and racers whistling
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202595
11/25/16 09:43 PM
11/25/16 09:43 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Cab- I was wondering about the timing tab not being correct, I just laughed it off thinking, nah that cannot be the problem.
The balancer is off a 67 383- maybe I should verify the TDC mark does line up. I seem to recall degreeing the cam, but it may have been in a different motor.... I don't know.
The distributor is a MSD knock off I got at a car show new in box, and my father is using my MSD box which is known to be good.
Maybe a new balancer and distributor is in order... Thanks for the ideas guys.
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202645
11/25/16 11:10 PM
11/25/16 11:10 PM
As said I would suggest: confirming true TDC. set initial with "vac gauge method". Limit total to 38 with the FBO $22 plate (initial+slots with can plugged) to 38. play with springs. plug in/adj the can. consider degreeing the cam. see what your cranking compression is. Holler how things turn out
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2202749
11/26/16 02:55 AM
11/26/16 02:55 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re-curve the distributor. Pop through the carb is usually lean, may need more accelerator pump shot.
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2204658
11/29/16 07:35 PM
11/29/16 07:35 PM
organ
maximum entropy Offline
organ
cab is right, those balancers slip all the time. also, 906 heads on a 383 makes about 3.5:1 compression ratio (maybe a little more, but you get the idea). stock stroke 383 takes work to end up with any real compression. that will be exacerbated by the cam reducing your dynamic c/r.
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2204770
11/29/16 10:24 PM
11/29/16 10:24 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Maybe you should confirm tdc first.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: slightly built 383 likes lots of timing?? [Re: 8urvette] #2205152
11/30/16 11:53 AM
11/30/16 11:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Pretty basic build-
383 .30 over
small tube headers
I had a .030 10:1 (or more) 383, w/ 509 cam, ported 915's (2.14/1.81), Torker II, 750DP and the usual stuff that loved timing. I had 42* in full at 2600rpm. A friend told me that was too high I should back it down to 38* and it slowed the car down. Another friend ran his 383 at 44*.
Coming soon!!!!
Re: slightly built 383 likes lots of timing?? [Re: Mr.Yuck] #2205169
11/30/16 12:28 PM
11/30/16 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty basic build-
383 .30 over
small tube headers
this is correct, 383's like timing , when I was at the pure stock drags one of the racers told me to bump the timing up to 42* , I chickened out and only went to 40* but the car did pick up some ...
