Re: slightly built 383 likes lots of timing??
[Re: 8urvette]
#2202310
11/25/16 01:41 PM
11/25/16 01:41 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I think 20 is fine but you might have to limit your total timing now but you wont know until you check it. Gus Treed by Doug
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 8urvette]
#2202433
11/25/16 04:49 PM
11/25/16 04:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If its a stock balancer it could have slipped some giving you some bad numbers... or like Doug said.. curve the dist.. but with a bigger cam(lumpy) it will want more base timing but still want about 36* total
[Re: 8urvette]
#2202645
11/25/16 11:10 PM
11/25/16 11:10 PM
RapidRobert
As said I would suggest: confirming true TDC. set initial with "vac gauge method". Limit total to 38 with the FBO $22 plate (initial+slots with can plugged) to 38. play with springs. plug in/adj the can. consider degreeing the cam. see what your cranking compression is. Holler how things turn out
[Re: 8urvette]
#2202749
11/26/16 02:55 AM
11/26/16 02:55 AM
Posts: 5,165 CT
GTX MATT
CT
Re-curve the distributor. Pop through the carb is usually lean, may need more accelerator pump shot.
[Re: 8urvette]
#2204658
11/29/16 07:35 PM
11/29/16 07:35 PM
Posts: 5,080 organ
maximum entropy
organ
cab is right, those balancers slip all the time. also, 906 heads on a 383 makes about 3.5:1 compression ratio (maybe a little more, but you get the idea). stock stroke 383 takes work to end up with any real compression. that will be exacerbated by the cam reducing your dynamic c/r.
[Re: 8urvette]
#2204770
11/29/16 10:24 PM
11/29/16 10:24 PM
Posts: 16,511 On the run…
BloFish
On the run…
Maybe you should confirm tdc first.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 8urvette]
#2205152
11/30/16 11:53 AM
11/30/16 11:53 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I was helping my pops out yesterday with his 383. Pretty basic build- 383 .30 over 906 heads, bigger valves, cleaned up ports small tube headers edelbrock intake- 750 holley DP carb lumpy cam- i dont remember the specs but i had called comp and talked to them and they suggested this cam for this engine. 9.5 to one compression.
once it is warmed up and idling at about 1100 if i hit the throttle it will backfire out the carb with the initial timing set at 12-15* if i change it to about 20* the idle drops a little and smooths out and does not have that hesitation but then i have mid 40's total at 2200+.
what is that about? Is this okay? I had a .030 10:1 (or more) 383, w/ 509 cam, ported 915's (2.14/1.81), Torker II, 750DP and the usual stuff that loved timing. I had 42* in full at 2600rpm. A friend told me that was too high I should back it down to 38* and it slowed the car down. Another friend ran his 383 at 44*.
[Re: Mr.Yuck]
#2205169
11/30/16 12:28 PM
11/30/16 12:28 PM
Posts: 75,074 U.S.S.A.
JohnRR
U.S.S.A.
what is that about? Is this okay? I had a .030 10:1 (or more) 383, w/ 509 cam, ported 915's (2.14/1.81), Torker II, 750DP and the usual stuff that loved timing. I had 42* in full at 2600rpm. A friend told me that was too high I should back it down to 38* and it slowed the car down. Another friend ran his 383 at 44*. this is correct, 383's like timing , when I was at the pure stock drags one of the racers told me to bump the timing up to 42* , I chickened out and only went to 40* but the car did pick up some ...
