Re: Cubic inches and boost
[Re: hudsonhornet7x]
#2204056
11/28/16 09:58 PM
11/28/16 09:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Use what you can still use a 6.20 Rod with IMO. Either of those in that case. The 3.58 could even do a stock Rod length or even jump to a 6.30.
Mopar to the bone!!!
#2204142
11/29/16 12:26 AM
11/29/16 12:26 AM
72Swinger
Nebraska
I calculated these with 6.125 rod. Any reason 6.2 is better? Just trying to understand. Thanks Longer rod= less Rod angle= lower thrust loading of cylinders which can also let the block take more power.
#2204314
11/29/16 10:56 AM
11/29/16 10:56 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would call a couple of piston manufacturers and see what they say about the needed ring pack and pin height required for the boost and cam you want to run. The more boost and the bigger the cam, the thicker the piston, etc. Ditto on the rods and crank. Sonic check the block. Then I would try to bend the ears of a couple of guys pushing these motors hard with boost to see just where the problems come up an how to build the motor to take it. You never know where this project will end up years down the road. Speed is addictive, plan for more boost/hp/cam now inside your budget. I look back at my last drag motor build and know that had I done it differently, I could be pushing 1100 hp instead of 880 hp for a few thou more. Good luck with it.
[Re: gregsdart]
#2204337
11/29/16 11:32 AM
11/29/16 11:32 AM
Posts: 1,543 USA
hudsonhornet7x
USA
I would call a couple of piston manufacturers and see what they say about the needed ring pack and pin height required for the boost and cam you want to run. The more boost and the bigger the cam, the thicker the piston, etc. Ditto on the rods and crank. Sonic check the block. Then I would try to bend the ears of a couple of guys pushing these motors hard with boost to see just where the problems come up an how to build the motor to take it. You never know where this project will end up years down the road. Speed is addictive, plan for more boost/hp/cam now inside your budget. I look back at my last drag motor build and know that had I done it differently, I could be pushing 1100 hp instead of 880 hp for a few thou more. Good luck with it. Good advice, I need to get some more info. Thanks!
#2204575
11/29/16 05:43 PM
11/29/16 05:43 PM
72Swinger
Nebraska
Decks on Gen III Hemis are all 6.239". Would love to see a 6.5" version.
[Re: 72Swinger]
#2204607
11/29/16 06:17 PM
11/29/16 06:17 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Decks on Gen III Hemis are all 6.239". Would love to see a 6.5" version. Goodness gracious, would love to see how those 6.300 long rods that you recommended would work in such a short deck height lol But I thought deck heights were as follows: 5.7L & 6.1L=9.252 6.4L & Hellcat=9.284
[Re: GTS340]
#2204778
11/29/16 10:36 PM
11/29/16 10:36 PM
72Swinger
Nebraska
Decks on Gen III Hemis are all 6.239". Would love to see a 6.5" version. Goodness gracious, would love to see how those 6.300 long rods that you recommended would work in such a short deck height lol But I thought deck heights were as follows: 5.7L & 6.1L=9.252 6.4L & Hellcat=9.284 Yeah I was still in rod length land lol! They're not all the same at 9.239". I guess the 5.7 is 9.25" and 6.4/6.2 is 9.284". I figured people swapping 6.4 and 6.1 intakes back and forth, they were the same. Learn something new everyday.
