Timing or carb? #2203638
11/28/16 12:10 AM
11/28/16 12:10 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
Another easy question for you guys, my 440 Challenger has a serious stumble when I try to accelerate in any gear at low RPM. If I really try to get on it, it'll backfire thru the carb. It's stock electronic distributor and Edelbrock 1413 Performer 800cfm carb.
Hint #2: It smells like its running too rich at idle.
I think I had the timing advanced a bit too much before (I can feel the power loss when I go too far) and may have backed it off a bit too much.
I know I should get the timing light out instead of doing it by ear (and tick marks I make on the distributor housing), but...I've been real leery of using timing lights ever since I was a teenager and wasted a lot of time diagnosing my 318 until I figured out the problem was caused by a stretched/jumped timing chain and using the timing light was giving me worthless readings.
Re: Timing or carb? [Re: Moparmaniacc] #2203648
11/28/16 12:23 AM
11/28/16 12:23 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Put a timing light on it!
Re: Timing or carb? [Re: Moparmaniacc] #2203654
11/28/16 12:32 AM
11/28/16 12:32 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yep you just have to know initial and total timing first.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Timing or carb? [Re: Moparmaniacc] #2203656
11/28/16 12:34 AM
11/28/16 12:34 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
One time I got some bad gas and ever since I've been real leery of putting gas in my car. smirk put a timing light on it
Re: Timing or carb? [Re: Moparmaniacc] #2203693
11/28/16 01:21 AM
11/28/16 01:21 AM
I'd check out the AP squirt (amt/duration) & set the timing at 15 on ported for a good start (note (& post) what it is now when you check/set it)
