Another easy question for you guys, my 440 Challenger has a serious stumble when I try to accelerate in any gear at low RPM. If I really try to get on it, it'll backfire thru the carb. It's stock electronic distributor and Edelbrock 1413 Performer 800cfm carb.
Hint #2: It smells like its running too rich at idle.
I think I had the timing advanced a bit too much before (I can feel the power loss when I go too far) and may have backed it off a bit too much.
I know I should get the timing light out instead of doing it by ear (and tick marks I make on the distributor housing), but...I've been real leery of using timing lights ever since I was a teenager and wasted a lot of time diagnosing my 318 until I figured out the problem was caused by a stretched/jumped timing chain and using the timing light was giving me worthless readings.
