4.7 questions
#2165167
09/30/16 03:54 PM
09/30/16 03:54 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I got a steal of a deal on an 07 dakota with the HO 4.7 from an auction, the heads were gone but the rest of the motor looks like new sitting in there, even the guides and chains look awesome but the intake and whole top end is gone. I found an 02 top end complete for real cheap, can I just bolt it all on and make it work? The interchange at the JY says only one head will swap, what could possibly be different? The truck does not have EGR. The intake is supposedly better from reading on the line but can't find any details of would keep me from useing the 02 intake even though the interchange says no way.
Re: 4.7 questions
[Re: HotRodDave]
#2165635
10/01/16 04:10 AM
10/01/16 04:10 AM
Posts: 4,848 Memphis
HemiRick
Memphis
passenger head has a cam tone ring that changed over the years
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 4.7 questions
[Re: HotRodDave]
#2165941
10/01/16 03:30 PM
10/01/16 03:30 PM
HotRodDave
Kalispell Mt.
I do know about the tone ring, the one for the truck was in the truck so I will use it but it is the drivers side head that is allegedly not interchangable.
Re: 4.7 questions
[Re: HotRodDave]
#2167101
10/03/16 03:30 PM
10/03/16 03:30 PM
HotRodDave
Kalispell Mt.
I am not fond of them, just happen to have worked on tons of em so I usually know my way around on em, just havent done much swapping amongst those particular years.
Re: 4.7 questions
[Re: HotRodDave]
#2168587
10/05/16 08:13 PM
10/05/16 08:13 PM
HotRodDave
Kalispell Mt.
I can buy super nice trucks all the time like this, I bought this one to size up dropping in a 5.7 but that looks like too much work so I will update everything and put it together and run it for a while or sell it.
Re: 4.7 questions
[Re: HotRodDave]
#2201534
11/24/16 12:08 AM
11/24/16 12:08 AM
HotRodDave
Kalispell Mt.
In case any one finds this in the future.
Everything bolted on just fine and it is the strongest running 4.7 I have driven. Silky smooth and tons o power, I am tempted to keep it but I just found a ram I think I want instead.
Re: 4.7 questions
[Re: HotRodDave]
#2202633
11/25/16 10:47 PM
11/25/16 10:47 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Glad your like you 4.7. I am looking for new heads for mine. So, if anyone can tell me the years that had EGR, I would appreciate it. 2003 in particular. Rock lists them EGR and non EGR for 2003. Then again, they list that on ALL 4.7s. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: 4.7 questions
[Re: buildanother]
#2203114
11/27/16 01:38 AM
11/27/16 01:38 AM
denfireguy
Colorado
Re: 4.7 questions
[Re: HotRodDave]
#2203367
11/27/16 04:08 PM
11/27/16 04:08 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
I can buy super nice trucks all the time like this, I bought this one to size up dropping in a 5.7 but that looks like too much work so I will update everything and put it together and run it for a while or sell it. To hard how? Motor mounts and custom pan then it's just wiring,hot wire makes that easy,just not cheap. 5.7 in an 02 Dak fits as well as or better than the 4.7 did,now if I would just wire it :-)
who is that guy?
Re: 4.7 questions
[Re: HotRodDave]
#2206271
12/02/16 01:53 AM
12/02/16 01:53 AM
HotRodDave
Kalispell Mt.
I don't make motor mounts, especially not in a 4x4 that ties the diff to it all also. The 4.7 computer will run the hemi but not optimally but if I was to swap a ram/durango/nitro... computer in than there are all kinds of computer comunication issues or spend a butt load of money on a programmer for the 4.7 computer.
Also on the 02 you better be carefull as they had a 16 tooth crank tone wheel and your existing computer will not run the hemi with it's 32 tooth wheel. If you want to use the later 4.7 ECU you will basically have to re-wire the whole truck as all the computers will no longer talk to each other and you will get a "no buss" warning on your dash and none of your gauges will work if the truck will even start with the security crap.
I have done a lot of swaps and they are never as easy as "just a little welding and fabrication". Everything seems easier reading it on the internet.
