Re: 8 1/4 brake question
[Re: sbhpcb]
#220215
02/11/09 07:48 AM
02/11/09 07:48 AM
Posts: 819 Lancashire, England
Jon_Smith
Best Laid Plans.....
Lancashire, England
I've had a look for an 8 3/4" axle... they're like rocking horse poo over here Besides, if they are the same backing plates I can still use the brakes if I upgrade the axle later The guy I bought tha axle off said he had used his 8 1/4 brakes on an 8 3/4 so I'm fairly sure myself that they'll swap, just want to make sure..
[Re: Jon_Smith]
#220216
02/11/09 07:59 AM
02/11/09 07:59 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
8.25 and 9.25 brakes are the same.
you can get 9" and 11" drums from dakotas and druangos, you can also get rear discs from them, some newer jeeps also have 8.25s with rear drums or discs that are already 5 lug patterns. brakes are as close as your nearest junk yard
**Photobucket sucks**
[Re: Jon_Smith]
#220218
02/12/09 05:16 AM
02/12/09 05:16 AM
70Cuda383
Marysville, O-H-I-O
not many dakotas and durangos in UK junkyards... may be some jeeps though thanks
HA! yea, probably not! I didn't look to see where you lived!
I have a bunch of brake stuff, 2 sets of drums, 1 set of backing plates, wheel cylinders, return springs, etc. let me know if you need any of it--it's for a dakota though, so the drums are 6 lug, but could be re-drilled for a 5.
or, I could go to the local u-pull-it, and grab a 5 lug drum brake set up off a jeep, or even a disc if I can find one, and I'll ship it all to you at my cost (parts from the junk yard plus shipping)
