Page 3 of 3 1 2 3
Re: Welder? [Re: charger440sixpak] #2201035
11/23/16 03:42 AM
11/23/16 03:42 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The tracking number Eastwood provided says mine is supposed to be delivered by FedEx tomorrow (Wednesday). weld
boogie
Re: Welder? [Re: SNK-EYZ] #2201111
11/23/16 11:46 AM
11/23/16 11:46 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Mine will be here today as well...
The sale must have done well..... they are on backorder now...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Welder? [Re: Sunroofcuda] #2201275
11/23/16 04:17 PM
11/23/16 04:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By Sunroofcuda
Originally Posted By JMCFAN
Originally Posted By chryslerconvert
I bought a mig 135 from Eastwood. Works great. 110 volts.
The Eastwood looks interesting...higher output than the Lincoln....
If you get a good 110 model, make sure it's on a dedicated 20 amp circuit with 12/2 wiring. My Century welder pulls a lot of amps & does just fine for a 110V. Also, make sure you have a full range of adjustments for wire speed & heat, not just 3 position lo, med, & hi click, click, click. You need to be able to fine tune the settings!
iagree
Re: Welder? [Re: PLUM_72] #2201450
11/23/16 09:52 PM
11/23/16 09:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted By PLUM_72
Hobart Handler 140. Nice 110 mig welder, look at the reviews online.
If you want to go pricey Miller Multimatic 200. Its a multiprocess welder, mig, tig, stick. It adjusts from 110v to 220.
Agree on the gas shielding, its a must! Nothing worse than weld spatter. If you use the MIG for sheet metal 110v is fine. If you plan to weld aluminum or thick 1/4"+ plate, you'll need the 220v.
I was thinking of mentioning a multi-process inverter welder too, but looks like they are minimum $600+.
I have an old (25+ year old) Hobart Handler 120 110-volt welder that has been really good, but the "Piecemaker" mig gun it came with is obsolete, so I got a conversion kit for it to use common replacement parts.
Earlier this year, I found a good deal on a Tweeco (same as Thermal Arc) 181i multi-process welder for $599. That is the lowest I have seen them, but only comes with the Mig welding gun setup. The Tig tourch and foot control were another $315.
I already had the cable and electrode holder for stick welding that I bought to use with my Miller Dynasty 280, but that could add around $100 to the cost of a multi-process machine setup if you plan to stick weld.
Re: Welder? [Re: JMCFAN] #2201475
11/23/16 10:28 PM
11/23/16 10:28 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Can't believe I have had my baby miller for over 20yrs now.
Sold a 318 to a guy over the weekend who owns a body shop,said he has the same unit.
who is that guy?
Re: Welder? [Re: Brian_wo] #2201488
11/23/16 10:55 PM
11/23/16 10:55 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If I could afford the expense I would have preferred to buy a Miller.
It's just not in the budget. frown
My new Eastwood mig welder arrived today as it was supposed to.
I use it at a hobby level so it should be fine.
Kayse's new studded snow tires arrived from Tire Rack also.
I already mounted them on the rims using the H/Freight manual tire changer I bought last Sunday.
I found the tire changer (used) on c/list, it came with all the stuff to do motorcycle and atv wheels (rim clamp) for $50.
Page 3 of 3 1 2 3
