Re: Welder?
[Re: 451Mopar]
#2198690
11/18/16 10:34 PM
11/18/16 10:34 PM
Posts: 2,096 New Mexico
JMCFAN
New Mexico
The Lincoln you listed looks OK, but is pretty weak on power output, I think the specs are 88 Amps, 20% duty cycle at 70-Amps, and a fixed flow regulator? I just looked up the Eastwood 135. Specs look better, 125 Amp max with 20% duty cycle at 90 Amps, had an adjustable regulator, and is on sale for $259.99 (price seems too good?) Get some solid core wire and a bottle of 75/25 CO2/Ar will give you nice clean welds. Flux core wire is ok, and should be used in areas where wind can blow the gas shield away, but it spatters quite a bit, and burns a bit hotter than the gas shield which is important when working with thin sheet metal. If you plan to weld often, you will likely outgrow these smaller welders, but the next cost point is at least double the cost of these entry level welders. Thanks! Ordering the Eastwood! Will upgrade when I get the shop addition and 220 in
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Welder?
[Re: DrCharles]
#2198753
11/19/16 12:25 AM
11/19/16 12:25 AM
JMCFAN
New Mexico
I clicked on the link just now and it says it's $199.99. Not bad at all! WOW... I had in my shopping cart for $259...and then your post came across.. Opened another window..and boom... $199.. Thanks.. saved me $60. Black Friday!!!
Re: Welder?
[Re: JMCFAN]
#2198802
11/19/16 02:42 AM
11/19/16 02:42 AM
Posts: 8,406 Highland, MI.
Sunroofcuda
Highland, MI.
I bought a mig 135 from Eastwood. Works great. 110 volts. The Eastwood looks interesting...higher output than the Lincoln.... If you get a good 110 model, make sure it's on a dedicated 20 amp circuit with 12/2 wiring. My Century welder pulls a lot of amps & does just fine for a 110V. Also, make sure you have a full range of adjustments for wire speed & heat, not just 3 position lo, med, & hi click, click, click. You need to be able to fine tune the settings!
Re: Welder?
[Re: JMCFAN]
#2198815
11/19/16 03:26 AM
11/19/16 03:26 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I clicked on the link just now and it says it's $199.99. Not bad at all! WOW... I had in my shopping cart for $259...and then your post came across.. Opened another window..and boom... $199.. Thanks.. saved me $60. Black Friday!!! Wow, $199.99! Great price.
Re: Welder?
[Re: 451Mopar]
#2198941
11/19/16 02:07 PM
11/19/16 02:07 PM
JMCFAN
New Mexico
I just checked and its back to $259.... I NEVER get that lucky.... ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Welder?
[Re: DrCharles]
#2199003
11/19/16 04:36 PM
11/19/16 04:36 PM
Posts: 10,161 A Red State
SNK-EYZ
A Red State
I checked again and shipping to MO is an extra $25 :P So much for free shipping.
Yes, definitely get a welder that can do both sizes. I just ordered the Eastwood mig welder myself. They consider it "Heavy" as far as shipping, that kills the free shipping ($24.10 shipping). The ATD mig welder (110 volt) I've been using for the last 33 years still works but has seen better days. It's obsolete (was British made) and parts are no longer available. I've patched it up (Miller trigger and hose) and replace other parts in it. I paid $350 for it new back then. I figure it was time for a new one. For the $200 price I decided I shouldn't put off buying a new one anymore. I use it for bodywork/sheet metal at a hobby type level so it should be fine. I've already got the Argon/CO2 gas bottle from the current welder, so I'm set there.
Re: Welder?
[Re: charger440sixpak]
#2199021
11/19/16 05:06 PM
11/19/16 05:06 PM
JMCFAN
New Mexico
Make sure you enter the discount code DIS00110 at checkout to get the $199.99 price. I didnt have to enter any code... price showed $199 last night,,,now back to $259 Just went and grabbed a HB stand. Need to buy a bottle as well... $99 at HB.... but with a 20% coupon wont be bad
Re: Welder?
[Re: BIGGERED]
#2199055
11/19/16 06:42 PM
11/19/16 06:42 PM
JMCFAN
New Mexico
$179 for this unit is insane... Nice!!
Re: Welder?
[Re: JMCFAN]
#2199152
11/19/16 10:42 PM
11/19/16 10:42 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
I just checked and its back to $259.... I NEVER get that lucky.... link on facebook took me right to it at $199 moments ago.
who is that guy?
Re: Welder?
[Re: JMCFAN]
#2200585
11/22/16 04:00 PM
11/22/16 04:00 PM
Posts: 1,238 Chicago, IL
PLUM_72
Chicago, IL
Hobart Handler 140. Nice 110 mig welder, look at the reviews online.
If you want to go pricey Miller Multimatic 200. Its a multiprocess welder, mig, tig, stick. It adjusts from 110v to 220.
Agree on the gas shielding, its a must! Nothing worse than weld spatter. If you use the MIG for sheet metal 110v is fine. If you plan to weld aluminum or thick 1/4"+ plate, you'll need the 220v.
1972 Dodge Challenger
Re: Welder?
[Re: mopars4ever]
#2200594
11/22/16 04:16 PM
11/22/16 04:16 PM
JMCFAN
New Mexico
I really hate to order heavy stuff like that online and have it shipped because it always seems to get damaged in some way. I usually try to find something local. Well mine will be here Friday... will let you know... ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
