Page 2 of 3 1 2 3
Re: Welder? [Re: 451Mopar] #2198690
11/18/16 10:34 PM
11/18/16 10:34 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Originally Posted By 451Mopar
The Lincoln you listed looks OK, but is pretty weak on power output, I think the specs are 88 Amps, 20% duty cycle at 70-Amps, and a fixed flow regulator?
I just looked up the Eastwood 135. Specs look better, 125 Amp max with 20% duty cycle at 90 Amps, had an adjustable regulator, and is on sale for $259.99 (price seems too good?)
Get some solid core wire and a bottle of 75/25 CO2/Ar will give you nice clean welds. Flux core wire is ok, and should be used in areas where wind can blow the gas shield away, but it spatters quite a bit, and burns a bit hotter than the gas shield which is important when working with thin sheet metal.
If you plan to weld often, you will likely outgrow these smaller welders, but the next cost point is at least double the cost of these entry level welders.
Thanks! Ordering the Eastwood!
Will upgrade when I get the shop addition and 220 in
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Welder? [Re: 6T6Cuda] #2198703
11/18/16 11:00 PM
11/18/16 11:00 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By 6T6Cuda
I clicked on the link just now and it says it's $199.99. Not bad at all!
Re: Welder? [Re: JMCFAN] #2198706
11/18/16 11:05 PM
11/18/16 11:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You did not say what you are welding?
Eastwood says this comes with the 0.023" wire which is good for thinner steel. I think it can also accept 0.030" wire for thicker stuff.
Use brand name wire. Some of the cheap off-band wire can cause problems that you may blame the welder.
Re: Welder? [Re: JMCFAN] #2198716
11/18/16 11:19 PM
11/18/16 11:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I checked again and shipping to MO is an extra $25 :P So much for free shipping.
Yes, definitely get a welder that can do both sizes.
Re: Welder? [Re: DrCharles] #2198753
11/19/16 12:25 AM
11/19/16 12:25 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
WOW... I had in my shopping cart for $259...and then your post came across.. Opened another window..and boom... $199.. Thanks.. saved me $60. Black Friday!!!
Re: Welder? [Re: JMCFAN] #2198802
11/19/16 02:42 AM
11/19/16 02:42 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Originally Posted By JMCFAN
Originally Posted By chryslerconvert
I bought a mig 135 from Eastwood. Works great. 110 volts.
The Eastwood looks interesting...higher output than the Lincoln....
If you get a good 110 model, make sure it's on a dedicated 20 amp circuit with 12/2 wiring. My Century welder pulls a lot of amps & does just fine for a 110V. Also, make sure you have a full range of adjustments for wire speed & heat, not just 3 position lo, med, & hi click, click, click. You need to be able to fine tune the settings!
Re: Welder? [Re: JMCFAN] #2198815
11/19/16 03:26 AM
11/19/16 03:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Wow, $199.99! Great price.
Re: Welder? [Re: 451Mopar] #2198941
11/19/16 02:07 PM
11/19/16 02:07 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I just checked and its back to $259....
I NEVER get that lucky.... up
Re: Welder? [Re: JMCFAN] #2198988
11/19/16 03:50 PM
11/19/16 03:50 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Make sure you enter the discount code DIS00110 at checkout to get the $199.99 price.
Re: Welder? [Re: DrCharles] #2199003
11/19/16 04:36 PM
11/19/16 04:36 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I just ordered the Eastwood mig welder myself.
They consider it "Heavy" as far as shipping, that kills the free shipping ($24.10 shipping).
The ATD mig welder (110 volt) I've been using for the last 33 years still works but has seen better days.
It's obsolete (was British made) and parts are no longer available.
I've patched it up (Miller trigger and hose) and replace other parts in it.
I paid $350 for it new back then. laugh2
I figure it was time for a new one.
For the $200 price I decided I shouldn't put off buying a new one anymore.
I use it for bodywork/sheet metal at a hobby type level so it should be fine.
I've already got the Argon/CO2 gas bottle from the current welder, so I'm set there.
Re: Welder? [Re: charger440sixpak] #2199021
11/19/16 05:06 PM
11/19/16 05:06 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I didnt have to enter any code... price showed $199 last night,,,now back to $259 shruggy
Just went and grabbed a HB stand. Need to buy a bottle as well... $99 at HB.... but with a 20% coupon wont be bad
Re: Welder? [Re: JMCFAN] #2199043
11/19/16 06:11 PM
11/19/16 06:11 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Thanks for the heads up on this.
Pricing varied from 199$ and up depending on when I added it to my cart so I used the above referenced code and it knocked it down to 199$ plus I'm a cheap skate and added the <10% email coupon knocking it down to 179.99 + shipping. All in 194.99$ delivered.
I realize it is not a "pro machine" but they sell a ton of them to hobbyists and most reviews are favorable.
Enjoy!
Red
Re: Welder? [Re: BIGGERED] #2199055
11/19/16 06:42 PM
11/19/16 06:42 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
$179 for this unit is insane... Nice!!
Re: Welder? [Re: Stanton] #2199122
11/19/16 09:19 PM
11/19/16 09:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By Stanton
That's a piece of crap
Aw c'mon John, stop beating around the bush and tell us what you really think.
laugh2 laugh2 laugh2 iagree with RR.
Re: Welder? [Re: JMCFAN] #2199152
11/19/16 10:42 PM
11/19/16 10:42 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
link on facebook took me right to it at $199 moments ago.
who is that guy?
Re: Welder? [Re: JMCFAN] #2199263
11/20/16 04:03 AM
11/20/16 04:03 AM
Washington/Las Vegas
1971 Gran Coupe Offline
It is 10PM here Pacific time and I just checked the link and it is still good. I even was able to get free shipping, but did not buy it, cause I bought there 175 Amp one a few months ago, just wanted to see if the good price was still working.
http://www.eastwood.com/mig-welder-110vac-135a-output.html?SRCCODE=DIS00110
Re: Welder? [Re: JMCFAN] #2200585
11/22/16 04:00 PM
11/22/16 04:00 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Hobart Handler 140. Nice 110 mig welder, look at the reviews online.
If you want to go pricey Miller Multimatic 200. Its a multiprocess welder, mig, tig, stick. It adjusts from 110v to 220.
Agree on the gas shielding, its a must! Nothing worse than weld spatter. If you use the MIG for sheet metal 110v is fine. If you plan to weld aluminum or thick 1/4"+ plate, you'll need the 220v.
1972 Dodge Challenger
Re: Welder? [Re: JMCFAN] #2200588
11/22/16 04:09 PM
11/22/16 04:09 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I really hate to order heavy stuff like that online and have it shipped because it always seems to get damaged in some way. I usually try to find something local.
Re: Welder? [Re: mopars4ever] #2200594
11/22/16 04:16 PM
11/22/16 04:16 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Well mine will be here Friday... will let you know... grin
Re: Welder? [Re: JMCFAN] #2201010
11/23/16 02:41 AM
11/23/16 02:41 AM
SF Bay Area, CA
SF Bay Area, CA
Ordered one on Sat. FedEx dropped it off today! Fastest I think I've gotten any thing that was shipped. Came from Reno, 66 lbs according to the box.
Page 2 of 3 1 2 3
