69 B-body Door - disassembly and reassembly procedure #2198950
11/19/16 02:23 PM
11/19/16 02:23 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Looking for help I'm determining the proper order of taking the glass, vent frame and entire guts out of a door for restoration, then to put it all back together
69 road runner coupe
Can anyone give a play by play?
Ed B
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Q5_Ed] #2198955
11/19/16 02:32 PM
11/19/16 02:32 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
up I could use that info as well
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Q5_Ed] #2199037
11/19/16 05:51 PM
11/19/16 05:51 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Excellent dip line photo!
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Q5_Ed] #2199066
11/19/16 07:10 PM
11/19/16 07:10 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
It's in the Factory Service Manual
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Q5_Ed] #2200393
11/22/16 02:14 AM
11/22/16 02:14 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Great picture! Thanks, I'm doing my doors right now, and this picture already helped!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 B-body Door - disassembly and reassembly procedure [Re: BigDaddy440] #2200403
11/22/16 03:33 AM
11/22/16 03:33 AM
Oh
His and Her 69's Offline
Oh
When I was doing my RR I kept going out and looking inside the door to see how things went together then I got the idea.
Cut the outside away so I can see stuff easier plus the door skin was junk anyways from rust and dents.
I cut it away and it made it so much easier to assemble my doors.
I did the quarter window area also as a cut away to help the reinstallation. I am glad I have a parts satellite to cut up for items and such.
Someone needed help so I posted this photo and I am glad it continues to help people out.
David
Re: 69 B-body Door - disassembly and reassembly procedure [Re: His and Her 69's] #2201101
11/23/16 11:31 AM
11/23/16 11:31 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
It is definitely helpful, I saved it to my reference picture files, do you have a pic of the cut away quarter showing the rear side window tracks?
jess
Yeah, it's hopped up to over 160...
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Q5_Ed] #2202164
11/25/16 12:53 AM
11/25/16 12:53 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I pull the regulator out, rear guide and the latch, etc... then remove the vent window and door glass together. You need to remove the cat whiskers etc 1st also... I reassembly the same way.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 69 B-body Door - disassembly and reassembly procedure [Re: Silver70] #2203772
11/28/16 05:50 AM
11/28/16 05:50 AM
Oh
Oh
Jess I found them on my computer for you.
I have an inner shot and an outer shot for you.
Hope it's what you wanted.
David
Re: 69 B-body Door - disassembly and reassembly procedure [Re: His and Her 69's] #2203778
11/28/16 09:02 AM
11/28/16 09:02 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Thanks David, those are perfect. They would be very helpful to anyone trying to reassemble one of these cars. (and so many are taken apart when found)
jess
