69 B-body Door - disassembly and reassembly procedure
#2198950
11/19/16 02:23 PM
11/19/16 02:23 PM
Posts: 1,896 New England
Q5_Ed
New England
Looking for help I'm determining the proper order of taking the glass, vent frame and entire guts out of a door for restoration, then to put it all back together
69 road runner coupe
Can anyone give a play by play?
Thanks Ed B
Re: 69 B-body Door - disassembly and reassembly procedure
[Re: Q5_Ed]
#2200393
11/22/16 02:14 AM
11/22/16 02:14 AM
Posts: 707 California
BigDaddy440
California
Great picture! Thanks, I'm doing my doors right now, and this picture already helped!
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: His and Her 69's]
#2201101
11/23/16 11:31 AM
11/23/16 11:31 AM
Posts: 1,567 Ky
jt4406
Ky
It is definitely helpful, I saved it to my reference picture files, do you have a pic of the cut away quarter showing the rear side window tracks?
jess
Yeah, it's hopped up to over 160...
[Re: Q5_Ed]
#2202164
11/25/16 12:53 AM
11/25/16 12:53 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I pull the regulator out, rear guide and the latch, etc... then remove the vent window and door glass together. You need to remove the cat whiskers etc 1st also... I reassembly the same way.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
#2203778
11/28/16 09:02 AM
11/28/16 09:02 AM
Posts: 1,567 Ky
jt4406
Ky
Thanks David, those are perfect. They would be very helpful to anyone trying to reassemble one of these cars. (and so many are taken apart when found) jess
