Page 2 of 3 1 2 3
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2190459
11/06/16 12:56 AM
11/06/16 12:56 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'll be sticking with a standalone Megasquirt ECU.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2196341
11/14/16 06:54 PM
11/14/16 06:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Is this for the VVT or the earlier engines and does it do the MDS stuff?
Re: Mopar is making a retrofit kit! [Re: HotRodDave] #2196464
11/14/16 10:25 PM
11/14/16 10:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
For 2014 to present. Runs factory 5.7 and 6.4.
So VVT and MDS are functional.
This I believe is the only true plug outfit for a 385 HP 5.7 and 485 HP 6.4.
Matt
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2196587
11/15/16 01:29 AM
11/15/16 01:29 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They could be manual trans engines without MDS so they can be used with any trans. That would make more sense.
Mopar to the bone!!!
Re: Mopar is making a retrofit kit! [Re: 72Swinger] #2196664
11/15/16 11:00 AM
11/15/16 11:00 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
You are correct.
Right from allpar.
The unlocked factory PCM has a custom calibration; the Mopar 345 Crate Hemi Engine Kit bumps horsepower to 383 and torque to 425 lb.ft. for the 5.7-liter (well above production stock), while the 392 Crate Hemi Engine Kit keeps the 6.4 at 485 horses and 472 lb.ft. of torque. The engines are designed for manual transmissions; automatic transmissions, such as the Torqueflite 727 and 904, while not optimal, can also be adapted.
Need to read before I post!
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2197407
11/16/16 04:57 PM
11/16/16 04:57 PM
MICHIGAN
Driftacular Offline
Driftacular  Offline
MICHIGAN
The kit works with 2013+ engines!
MattW is very right, the crank target wheel and sensor is different 2012 and prior.
what else is different on a older engine, I'm not sure.
No MDS btw.
As for the canadian prices... find a place that will give you some percent off.. price is MSRP. already seeing it online for cheaper, like 1560$ USD. Thats 2093$ CAD today..
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2197434
11/16/16 05:33 PM
11/16/16 05:33 PM
USA
hudsonhornet7x Offline
USA
I wonder if this would work with a hellcat?
Re: Mopar is making a retrofit kit! [Re: hudsonhornet7x] #2197486
11/16/16 07:09 PM
11/16/16 07:09 PM
MICHIGAN
Driftacular Offline
Driftacular  Offline
MICHIGAN
nope.
Re: Mopar is making a retrofit kit! [Re: MattW] #2199201
11/20/16 12:42 AM
11/20/16 12:42 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Originally Posted By MattW
Called mopar performance and they said its unlocked. Diablo and away you go!
This could be the answer to many problems with retrofitting this engine.
Matt
What is a Diablo?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Mopar is making a retrofit kit! [Re: AZ_A12_BEE] #2199204
11/20/16 12:48 AM
11/20/16 12:48 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Matt
What is a Diablo?
Handheld tuner that you can load flash tunes onto. You may be able to tune on-the-fly with it?
2020 RAM 1500
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2200022
11/21/16 04:34 PM
11/21/16 04:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I thought the 5.7 was making 395 in the newer trucks, 345 was the 03-08 rating? Seems if it is for the newer truck engine (most redily available of the 2013+ engine) it will make less HP not more... I am confused
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2200674
11/22/16 06:33 PM
11/22/16 06:33 PM
MICHIGAN
Driftacular Offline
Driftacular  Offline
MICHIGAN
345 is the displacement. 345 cubic inch = 5.653L .. so 5.7L.
it makes 383 HP, 425 torque.
current ram is 395hp, 410 torque. (but this is a different variant of the 5.7L hemi)
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2200813
11/22/16 10:11 PM
11/22/16 10:11 PM
Canada
WO23Coronet Online content OP
WO23Coronet  Online Content OP
Canada
The ram 5.7 has a different intake that's supposed to make better power, but I suspect it's a lot of "pen and paper dyno numbers". I think besides the intake they're the same motor (cam, heads, compression etc)
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2200816
11/22/16 10:15 PM
11/22/16 10:15 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Originally Posted By WO23Coronet
The ram 5.7 has a different intake that's supposed to make better power, but I suspect it's a lot of "pen and paper dunk numbers". I think besides the intake they're the same motor (cam, heads, compression etc)
Don't know why its only 383 hp and the new ram is 395.
Can't be the intake on the ram cuz they use a variable intake on the 6.4. So they should be able to do the ram also?
Matt
Re: Mopar is making a retrofit kit! [Re: MattW] #2201011
11/23/16 02:44 AM
11/23/16 02:44 AM
Canada
Canada
The 5.7 crate uses the car intake, I think the truck intake is the "reason" the Rams rated at 395.
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2201045
11/23/16 04:57 AM
11/23/16 04:57 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think the truck intake is variable runner as well.
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2201532
11/24/16 12:05 AM
11/24/16 12:05 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a 2011 ram 5.7 intake here and it is variable
Re: Mopar is making a retrofit kit! [Re: GoodysGotaCuda] #2293237
04/24/17 02:26 PM
04/24/17 02:26 PM
MI.
mech440 Offline
mech440  Offline
MI.
I called Diablo today as I'm almost ready to start my 6.4 and I bought the mopar crate wiring and computer kit. Diablo stated that they do not have anything that support this PCM? I was told that the PCm is umlocked but their software may "re-lock it"
I'm not sure if the guy knew what he was talking about... anyone else have any input on this issue?? Thanks.
Mech
If it doesn't have a motor.....it's not a REAL sport
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2293611
04/25/17 12:58 AM
04/25/17 12:58 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Call BFNY.(440) 787-7235
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2296051
04/29/17 01:02 PM
04/29/17 01:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Pushed like hell for MP to sell that 2006-7-8-9-10-11-12 and 13.
Multiple lists of part numbers created by my coworkers, countless emails and discussions why it would be a great idea, hours and hours spent trying to convince people, etc.
Better late than never, right?
In the time between '13 and today, how many customers got tired of waiting and went the LS route? Only a couple, right? LOLzz
Rich H.
Esse Quam Videri
Page 2 of 3 1 2 3
