Limits of bellhousing #2200082
11/21/16 06:14 PM
11/21/16 06:14 PM
Spencer NY
killermopar Offline OP
Spencer NY
What would the hp, tq limits of a 70 aluminum big block Bell? Planning on using some big meats, and slicks once in a while.
Re: Limits of bellhousing [Re: killermopar] #2200095
11/21/16 06:40 PM
11/21/16 06:40 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
not sure where you plan to run the slicks but of its on a track it will require a scattershield I believe
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Limits of bellhousing [Re: killermopar] #2200099
11/21/16 06:44 PM
11/21/16 06:44 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Depends on how much you need your feet.
Have a great day
Iowan
"obsolete is neat"
Re: Limits of bellhousing [Re: killermopar] #2200131
11/21/16 07:32 PM
11/21/16 07:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You are not going to break an aluminum bellhousing without a major violent vibration, exploding clutch, or heavy impact.
However, you are pushing your luck BIG TIME by not putting a scattershield between your body and that clutch when playing with slicks.
- Stu Harmon
Re: Limits of bellhousing [Re: killermopar] #2200134
11/21/16 07:34 PM
11/21/16 07:34 PM
Spencer NY
Spencer NY
Good enough. I'm building a street strip car. It's going to have a 500 low deck in it. I was thinking a scattershield is the best plan of attack, but I got a good deal on this Bell, and was looking for some insight. Thank you
Re: Limits of bellhousing [Re: killermopar] #2200136
11/21/16 07:38 PM
11/21/16 07:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you got a good deal on it maybe you can sell or swap it for a Lakewood. Make sure you get the block saver plate if you do a used Lakewood.
- Stu Harmon
Re: Limits of bellhousing [Re: feets] #2200283
11/22/16 12:04 AM
11/22/16 12:04 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have cracked or broken a few stock bellhousings one in aluminum and two cast steel. As said vibration, loose bolts, clutch/flywheel shrapnel, and severe transmission problems can kill a stock bell easily. If you don't need a SFI cert look around for a used Lakewood with a removable inspection plate. The inspection plate makes life so much easier.
Re: Limits of bellhousing [Re: killermopar] #2200293
11/22/16 12:27 AM
11/22/16 12:27 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
As stated in the second post, if you run slicks at the track you will need to have a scatter shield . Have a track that doesn't check for safety items ? Just do yourself and others a favor and get a scatter shield . Will something happen? probably not if you have a name brand flywheel and pressure plate. But as stated above , how do you like your feet, or the rest of your car. I have seen myself 2 clutch explosions in my time of drag racing, both were flywheel , both blew up through the cars breaking the drivers feet and continuing up through the dash / windshield destroying both cars. The first one killed a spectator. After seeing that , I myself ordered a Lakewood, best investment you'll ever make.
Re: Limits of bellhousing [Re: rowin4] #2200314
11/22/16 12:41 AM
11/22/16 12:41 AM
Washington
madscientist Offline
Washington
The rule is, if you are 11.50 or slower, you don't need a scatter shield. This is as per the rule book and verified by the division 6 tech inspector.
11.49 and quicker you need a scatter shield. Also, you don't need a cert on your can at 11.50 and slower.
Makes zero difference what tires you run and it is NOT a track option.
Re: Limits of bellhousing [Re: madscientist] #2200337
11/22/16 01:03 AM
11/22/16 01:03 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Not to steal the post, but to add another angle. Street car with factory tires, how much HP/ Tq could an aluminum bell take?
Re: Limits of bellhousing [Re: killermopar] #2200365
11/22/16 01:34 AM
11/22/16 01:34 AM
rowin4 Offline
rowin4  Offline
There's a Lakewood in the for sale, engines section.
Re: Limits of bellhousing [Re: madscientist] #2200368
11/22/16 01:38 AM
11/22/16 01:38 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
OK, that's the rule, but unless the engine (and the rest of the drivetrain) is stock, I won't run a manual transmission without a scattershield. I need my feet too.
twocents wave
Re: Limits of bellhousing [Re: DrCharles] #2200375
11/22/16 01:42 AM
11/22/16 01:42 AM
Washington
Washington
twocents wave
You and me both, but it was mentioned that if you run slicks you need a scatter shield. That's not the rule.
Re: Limits of bellhousing [Re: madscientist] #2204062
11/28/16 10:02 PM
11/28/16 10:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
QuickTime owns Lakewood.
Quicktime is light years ahead of Lakewood in every way.
Re: Limits of bellhousing [Re: Leon441] #2204072
11/28/16 10:15 PM
11/28/16 10:15 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Sort of right.......Holley owns them both
Re: Limits of bellhousing [Re: killermopar] #2204078
11/28/16 10:22 PM
11/28/16 10:22 PM
Spencer NY
Spencer NY
I want a scattershield. I didn't figure the bell would hold a stroker big block anyway. I got a great deal on the bell, and will probably list it.
Re: Limits of bellhousing [Re: Leon441] #2204089
11/28/16 10:48 PM
11/28/16 10:48 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I have owned both. Both have a specific purpose. I don't think either is "Light years" ahead of the other. It just depends on your setup.
[image][/image]
