Limits of bellhousing
#2200082
11/21/16 06:14 PM
11/21/16 06:14 PM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
What would the hp, tq limits of a 70 aluminum big block Bell? Planning on using some big meats, and slicks once in a while.
Re: Limits of bellhousing
[Re: killermopar]
#2200095
11/21/16 06:40 PM
11/21/16 06:40 PM
Posts: 12,216 NO RUST IN AZ!!!
azmopar
NO RUST IN AZ!!!
What would the hp, tq limits of a 70 aluminum big block Bell? Planning on using some big meats, and slicks once in a while. not sure where you plan to run the slicks but of its on a track it will require a scattershield I believe
70 Challenger Convertible 340 six pak CLONE? 70 Duster real FM3 car 65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
[Re: killermopar]
#2200099
11/21/16 06:44 PM
11/21/16 06:44 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Depends on how much you need your feet.
Have a great day Iowan
"obsolete is neat"
[Re: killermopar]
#2200131
11/21/16 07:32 PM
11/21/16 07:32 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You are not going to break an aluminum bellhousing without a major violent vibration, exploding clutch, or heavy impact.
However, you are pushing your luck BIG TIME by not putting a scattershield between your body and that clutch when playing with slicks.
[Re: killermopar]
#2200136
11/21/16 07:38 PM
11/21/16 07:38 PM
feets
Senior Management
Senior Management
Irving, TX
If you got a good deal on it maybe you can sell or swap it for a Lakewood. Make sure you get the block saver plate if you do a used Lakewood.
[Re: killermopar]
#2200293
11/22/16 12:27 AM
11/22/16 12:27 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
As stated in the second post, if you run slicks at the track you will need to have a scatter shield . Have a track that doesn't check for safety items ? Just do yourself and others a favor and get a scatter shield . Will something happen? probably not if you have a name brand flywheel and pressure plate. But as stated above , how do you like your feet, or the rest of your car. I have seen myself 2 clutch explosions in my time of drag racing, both were flywheel , both blew up through the cars breaking the drivers feet and continuing up through the dash / windshield destroying both cars. The first one killed a spectator. After seeing that , I myself ordered a Lakewood, best investment you'll ever make.
[Re: rowin4]
#2200314
11/22/16 12:41 AM
11/22/16 12:41 AM
Posts: 4,457 Washington
madscientist
Washington
As stated in the second post, if you run slicks at the track you will need to have a scatter shield . Have a track that doesn't check for safety items ? Just do yourself and others a favor and get a scatter shield . Will something happen? probably not if you have a name brand flywheel and pressure plate. But as stated above , how do you like your feet, or the rest of your car. I have seen myself 2 clutch explosions in my time of drag racing, both were flywheel , both blew up through the cars breaking the drivers feet and continuing up through the dash / windshield destroying both cars. The first one killed a spectator. After seeing that , I myself ordered a Lakewood, best investment you'll ever make. The rule is, if you are 11.50 or slower, you don't need a scatter shield. This is as per the rule book and verified by the division 6 tech inspector. 11.49 and quicker you need a scatter shield. Also, you don't need a cert on your can at 11.50 and slower. Makes zero difference what tires you run and it is NOT a track option.
[Re: DrCharles]
#2200375
11/22/16 01:42 AM
11/22/16 01:42 AM
madscientist
Washington
The rule is, if you are 11.50 or slower, you don't need a scatter shield. This is as per the rule book and verified by the division 6 tech inspector. OK, that's the rule, but unless the engine (and the rest of the drivetrain) is stock, I won't run a manual transmission without a scattershield. I need my feet too. You and me both, but it was mentioned that if you run slicks you need a scatter shield. That's not the rule.
[Re: madscientist]
#2204062
11/28/16 10:02 PM
11/28/16 10:02 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
QuickTime owns Lakewood. Quicktime is light years ahead of Lakewood in every way.
[Re: Leon441]
#2204072
11/28/16 10:15 PM
11/28/16 10:15 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
QuickTime owns Lakewood. Quicktime is light years ahead of Lakewood in every way. Sort of right.......Holley owns them both
[Re: Leon441]
#2204089
11/28/16 10:48 PM
11/28/16 10:48 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
QuickTime owns Lakewood. Quicktime is light years ahead of Lakewood in every way. I have owned both. Both have a specific purpose. I don't think either is "Light years" ahead of the other. It just depends on your setup.
[image][/image]
