Getting fed up and Needing some ignition advice
#2199842
11/21/16 09:56 AM
11/21/16 09:56 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Running stock mopar wiring(new harnesses) on a 470 stroker. I have the firecore distributor and wires, the revvnator box (although I haven't used it yet, still running the orange box), the distributor is junk (never ran right, found out the magnetic pickup came loose, brand new unit with less than 100 km on the damn thing) I'm just so sick and tired of not having my car run right, buying new products and having them fail out of the box, I just want to start my car and drive when I turn the key. Is that too hard to ask???!!! I've already eliminated the voltage regulator by using the upgraded denso unit, I did the bulkhead by pass upgrade, Is there anything else I can do to make my life easier? I think I'll be buying the FItech EFI unit, and I would like a distributor or ignition system that was trouble free. What distributors would you recommend? Please help! This winter I want to eliminate the BS and just be able to drive the car when spring arrives.
Re: Getting fed up and Needing some ignition advice
[Re: dangina]
#2199847
11/21/16 10:43 AM
11/21/16 10:43 AM
Posts: 4,674 Wichita
GY3
Wichita
I've always had good luck recurving a stock, electronic pickup Chrysler distributor to an MSD 6AL analog box. Car is stone reliable, starts instantly, looks stock (MSD is hidden) and gets good mileage. I installed a dial rev limiter so I can adjust it.
I feel your pain, though, as we recently tried a DIGITAL 6AL box on a Roadrunner and it was junk out of the box.
[Re: dangina]
#2199937
11/21/16 01:38 PM
11/21/16 01:38 PM
RapidRobert
found out the magnetic pickup came loose, brand new unit with less than 100 km on the damn thing) What distributors would you recommend? Sounds like the mini pop rivet came loose and gave erratic timing/hard starting/incorrect timing and or took out the reluctor teeth (rare on the rivet but has happened). I would replace what is damaged & its likely just as easy to get a used 70's electronic dist. reduce lower shaft end play to .005". check/fix bottom tang to intergear slot interface rotational play. check/correct rotor phasing as needed. longer rotor from NAPA or make your own blade (drill out the rivet) to reduce terminal tip gap to .015". set initial/total/spring combo/vac can (if used) in order. You can solder in a side oiler like the 60's dists used (they are available). this will give you a reliable dist, you have the box and I am assuming a coil to match & firecore plug wires get rave reviews. get a tan cap with ribs and brass terminals from Joesixpack
[Re: 451Mopar]
#2199982
11/21/16 03:03 PM
11/21/16 03:03 PM
RapidRobert
The timing control uses a standard two wire magnetic pickup distributor with the advance curve locked out, so a stock magnetic unit should work once the advance is locked out, you could get a std 70's electronic dist with the vac can then on your bench pump up the can with a vacuum pump till the rotor phasing is dead on (if/as needed to correct it if needed) then drill straight down thru the 2 plates & lock em in that position with a small bolt/nut with a spacer inbetween the 2 plates to keep em from tilting as the bolt is tightened. Not sure how I would lock out the weights (never done it) but with a visual it wouldn't be too hard to (easily) solve. EDIT Likely I would make a plate like the FBO unit then nothing is changed/altered & can easily be returned to stock at a later date as things change. MORE EDIT Then you can remove the can & cover the rectangular opening for a more aesthetic appearance.
[Re: DAYCLONA]
#2200028
11/21/16 04:43 PM
11/21/16 04:43 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I subscribe to K.I.S.S. engineering when it comes to ignition systems, I've been running Pertronix hardware since it's inception in the late 80's/early 90's on Industrial, Marine, DD's, the toys, racecars, you name it with NEVER a single failure to date with any Pertronix component...I've been thru all the other systems on the market, I feel your angst Pertronix "plug and play" billet distributor on my 440.. 10 years and never has missed a beat...
[Re: TJP]
#2200080
11/21/16 06:10 PM
11/21/16 06:10 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Exactly the opposite in my "neck of the woods", All the local parts stores (Advance/CQ/AZ/NAPA/etc/etc) all carry Pertronix, MSD, Accel, etc, etc regularly stocked...trying to find points/condensor, ballast resistor or even a stock ECU is near impossible, plus trying to educate the counter person what those components are, compound the matter!
[Re: dangina]
#2200196
11/21/16 09:32 PM
11/21/16 09:32 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Hello. Very sorry about the problem. We've had some of these that just couldn't get running right, but not many after the updates we've made. Especially the Electronic units. Great luck with them. Did you cal and did we speak? Troy at RT Garage insists on taking all of the tech calls.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: DAYCLONA]
#2200323
11/22/16 12:50 AM
11/22/16 12:50 AM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
Exactly the opposite in my "neck of the woods", All the local parts stores (Advance/CQ/AZ/NAPA/etc/etc) all carry Pertronix, MSD, Accel, etc, etc regularly stocked...trying to find points/condensor, ballast resistor or even a stock ECU is near impossible, plus trying to educate the counter person what those components are, compound the matter! You may be an exception to the rule. 15 years ago finding replacement parts for an after market ignition system was a Pray to ?? At that time they typically did not have replacement parts but "had a new system" on the shelf for XXX amount. So here we are 15 years later and while Your locality may offer support, drive 1 or 200 miles out of town for a 'smaller" car show, have your AFTER MARKET, Special, rotor, cap, control module take a dump. 30+ years ago I got stuck in the middle of a LARGE populated area (think SILICON VALLEY) with a broken "SPECIAL" Mallory rotor. We had a lot of local speed shops that MAY have had the SPECIAL Mallory rotor, but they were all closed. Keeping in mind this was 30+ years ago, There were multiple "SERVICE STATIONS" (yeah remember those/) with tune up cabinets Stocked full of REPLACEMENT OEM Parts, and they were within walking distance and OPEN. IF your local parts boys can't find a factory replacement component for an electronic ignition system produced since 1975, maybe you need to help them ??? No offense meant to you for your opinion, Just a extrapolation on mine
[Re: sunroofgtx]
#2200382
11/22/16 01:53 AM
11/22/16 01:53 AM
dangina
Hello. Very sorry about the problem. We've had some of these that just couldn't get running right, but not many after the updates we've made. Especially the Electronic units. Great luck with them. Did you cal and did we speak? Troy at RT Garage insists on taking all of the tech calls. I haven't called yet, I bought the distributor over two years ago at the beginning of the build, now a couple years later I finally get to drive my car and had nothing but problems all summer, its just frustrating having brand new parts that fail, especially in canada as we already pay more for these parts, shipping, duties ect. Yours isn't the first part that this has happened, its just one of many that has prevented me from enjoying my hard labor, wasted dyno time, money, ect, and it pains me to have it sit there, its just the straw that broke the camels back...
