Running stock mopar wiring(new harnesses) on a 470 stroker. I have the firecore distributor and wires, the revvnator box (although I haven't used it yet, still running the orange box), the distributor is junk (never ran right, found out the magnetic pickup came loose, brand new unit with less than 100 km on the damn thing) I'm just so sick and tired of not having my car run right, buying new products and having them fail out of the box, I just want to start my car and drive when I turn the key. Is that too hard to ask???!!! I've already eliminated the voltage regulator by using the upgraded denso unit, I did the bulkhead by pass upgrade, Is there anything else I can do to make my life easier? I think I'll be buying the FItech EFI unit, and I would like a distributor or ignition system that was trouble free. What distributors would you recommend? Please help! This winter I want to eliminate the BS and just be able to drive the car when spring arrives.
