Re: Assembled my 5.7L Hemi today!
[Re: cudadoug]
#2176187
10/16/16 06:07 PM
10/16/16 06:07 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What application is that front cover?
Any pics by chance with the alternator mocked up? Typical car application, I believe. The alternator is on the picture above, are you needing to see it in the car?
[Re: GoodysGotaCuda]
#2176199
10/16/16 06:20 PM
10/16/16 06:20 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Any pics by chance with the alternator mocked up? Typical car application, I believe. The alternator is on the picture above, are you needing to see it in the car? Ohhhh, scrolled right past that pic, thanks!
[Re: RTSrunner]
#2198851
11/19/16 10:49 AM
11/19/16 10:49 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What year engine/heads are you using? Cam? It's going to look good in the 'Cuda! It's a plain pre-Eagle 5.7L and a custom Comp cam. I spent my go-fast money on the T56 Magnum and will likely add some light boost to the 5.7 after the bugs are worked out of the car. I opened up the ring gaps a bit to help that happen.
