Hood Springs A-Body? #2198162
11/17/16 08:41 PM
11/17/16 08:41 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Looking to lubricate the pivots and hood springs. Would you pack grease in the coil spring? What works best on the loose pivots?
thx matt
[img] [/img]
Re: Hood Springs A-Body? [Re: clonestocker] #2198259
11/17/16 11:48 PM
11/17/16 11:48 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Probably a drop of motor oil on the pivot points every now and then? If you use grease don't use too much as it will attract dust and that could make things worse.
