Oh Man!!! What a Can of Worms #2197478
11/16/16 06:52 PM
11/16/16 06:52 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Been doing some updates on my cooling system. Finished everything up and topped off the coolant, took it for a drive. Well, I just found out that I have other cooling issues. Apparently the freeze plugs on the passenger side are leaking. With the system nut under pressure it doesn't seem so bad but put the rad cap on (16psi) and all three leak like a sieve. I haven't checked the driver side yet.
Being a big block Dart the motor will have to come out. What bothers me is that this is a fresh motor, probably no more than 2500 miles driven on it. Guess I won't know the cause of the freeze plug leaks until I get the motor out.
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197526
11/16/16 08:07 PM
11/16/16 08:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Put brass freeze plugs in it...... You won't have to deal with this issue again.
Re: Oh Man!!! What a Can of Worms [Re: fast68plymouth] #2197539
11/16/16 08:53 PM
11/16/16 08:53 PM
Use Permatex #1 the thick viscous gasket cement in the toothpaste like tube and get freeze plugs that are wide. clean the perimeter well
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197554
11/16/16 09:38 PM
11/16/16 09:38 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Are they leaking between the plug and block or are the rusted through from the back side?
Doug
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197555
11/16/16 09:38 PM
11/16/16 09:38 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Are they leaking between the plug and block or are the rusted through from the back side? I'd support the motor and drop the K-frame before I pulled the motor.
Doug
Re: Oh Man!!! What a Can of Worms [Re: RapidRobert] #2197566
11/16/16 09:59 PM
11/16/16 09:59 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I think most core plugs (freeze plugs if you want) are available in shallow and wide. The shallow ones are just asking for trouble in my experience. And brass is probably a good idea along with some non-hardening Permatex.
Master, again and still
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197596
11/16/16 10:46 PM
11/16/16 10:46 PM
Tacoma, Washington USA
Adam71Charger Offline
Ive used the rubber sandwich type in tight spots. If you can get the old ones out without taking the engine out, the rubber ones just slide in and then you tighten the nut and it expands and seals. They have worked great on 2 different engines Ive helped family out with. There was no way I was taking the engine out of my sisters 89 buick to replace core plugs, which I wouldve had to if I chose traditional core plugs.
Never used them on a nice car though, they are a little goofy looking, but they work
Re: Oh Man!!! What a Can of Worms [Re: dvw] #2197605
11/16/16 10:53 PM
11/16/16 10:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Doug
I think I could pull an engine faster than dropping a k-member
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197620
11/16/16 11:15 PM
11/16/16 11:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Do yourself a favor and replace ALL of them while it is out. I also like to remove the block drain plugs and install petcocks so future draining of the block is easier.
Don't be the exception.
Re: Oh Man!!! What a Can of Worms [Re: fast68plymouth] #2197633
11/16/16 11:28 PM
11/16/16 11:28 PM
Mesa, Arizona
Mesa, Arizona
They were brass
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: cudaman1969] #2197636
11/16/16 11:30 PM
11/16/16 11:30 PM
Mesa, Arizona
Mesa, Arizona
Doug
I'm kinda debating that in my own mind. Problem is it's a big block Dart. Not much room under there.
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: Supercuda] #2197637
11/16/16 11:31 PM
11/16/16 11:31 PM
Mesa, Arizona
Mesa, Arizona
Yeah, no reason to take a chance on the driver side
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: dvw] #2197643
11/16/16 11:35 PM
11/16/16 11:35 PM
Mesa, Arizona
Mesa, Arizona
Doug
Leaking between the plug and the block
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197671
11/16/16 11:53 PM
11/16/16 11:53 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Were they dry on install?
A few here will know better than me but I have always used the Indian Head Shellac on soft plugs...brass or steel... twocents
Don't be afraid to just pull the K frame...I think its actually easier... twocents
...FAFO...
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197672
11/16/16 11:54 PM
11/16/16 11:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Mix up some alumaseal in a cup with some water, pour the mixture in there and drive it for the rest of the winter. Drop the motor out from the bottom in the spring and replace all those plugs.
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197688
11/17/16 12:08 AM
11/17/16 12:08 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'm available to lend a hand if you decide to tackle it.
Re: Oh Man!!! What a Can of Worms [Re: jbc426] #2197699
11/17/16 12:23 AM
11/17/16 12:23 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Learned the lesson on dry freeze plug installation on my last new engine. Pulled the leaking ones out (luckily just 3 in relatively easy to access locations) and used Permatex form-a-gasket 1B, the hardening type, and that solved it.
Re: Oh Man!!! What a Can of Worms [Re: Belvedere1] #2197704
11/17/16 12:27 AM
11/17/16 12:27 AM
Mesa, Arizona
Mesa, Arizona
I was planning a trip up to WA state next month. May load it up and take it with me. I'll have a hoist where we can drop everything out the bottom.
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: Belvedere1] #2197706
11/17/16 12:30 AM
11/17/16 12:30 AM
Mesa, Arizona
Mesa, Arizona
Hey, thanks for the offer. I was under the car this afternoon. The only plug assessable is the center. The rear plug is blocked by the exhaust manifold. The front plug is blocked by the motor mount.
Abe Lincoln
Re: Oh Man!!! What a Can of Worms [Re: dart4forte] #2197721
11/17/16 12:43 AM
11/17/16 12:43 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Sure, no problem. I was able to change one in the Belvedere once but it was a bear, I couldn't imagine attempting it on the Dart.
