Oh Man!!! What a Can of Worms
#2197478
11/16/16 06:52 PM
11/16/16 06:52 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Been doing some updates on my cooling system. Finished everything up and topped off the coolant, took it for a drive. Well, I just found out that I have other cooling issues. Apparently the freeze plugs on the passenger side are leaking. With the system nut under pressure it doesn't seem so bad but put the rad cap on (16psi) and all three leak like a sieve. I haven't checked the driver side yet.
Being a big block Dart the motor will have to come out. What bothers me is that this is a fresh motor, probably no more than 2500 miles driven on it. Guess I won't know the cause of the freeze plug leaks until I get the motor out.
Abe Lincoln
Re: Oh Man!!! What a Can of Worms
[Re: dart4forte]
#2197526
11/16/16 08:07 PM
11/16/16 08:07 PM
fast68plymouth
So. Burlington, Vt.
Put brass freeze plugs in it...... You won't have to deal with this issue again.
[Re: fast68plymouth]
#2197539
11/16/16 08:53 PM
11/16/16 08:53 PM
RapidRobert
Use Permatex #1 the thick viscous gasket cement in the toothpaste like tube and get freeze plugs that are wide. clean the perimeter well
[Re: RapidRobert]
#2197566
11/16/16 09:59 PM
11/16/16 09:59 PM
Posts: 12,253 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I think most core plugs (freeze plugs if you want) are available in shallow and wide. The shallow ones are just asking for trouble in my experience. And brass is probably a good idea along with some non-hardening Permatex.
Master, again and still
[Re: dvw]
#2197605
11/16/16 10:53 PM
11/16/16 10:53 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Are they leaking between the plug and block or are the rusted through from the back side? I'd support the motor and drop the K-frame before I pulled the motor. Doug I think I could pull an engine faster than dropping a k-member
[Re: dart4forte]
#2197620
11/16/16 11:15 PM
11/16/16 11:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Do yourself a favor and replace ALL of them while it is out. I also like to remove the block drain plugs and install petcocks so future draining of the block is easier.
#2197633
11/16/16 11:28 PM
11/16/16 11:28 PM
dart4forte
Mesa, Arizona
Put brass freeze plugs in it...... You won't have to deal with this issue again. They were brass
Abe Lincoln
[Re: cudaman1969]
#2197636
11/16/16 11:30 PM
11/16/16 11:30 PM
dart4forte
Mesa, Arizona
Are they leaking between the plug and block or are the rusted through from the back side? I'd support the motor and drop the K-frame before I pulled the motor. Doug I think I could pull an engine faster than dropping a k-member I'm kinda debating that in my own mind. Problem is it's a big block Dart. Not much room under there.
Abe Lincoln
[Re: Supercuda]
#2197637
11/16/16 11:31 PM
11/16/16 11:31 PM
dart4forte
Mesa, Arizona
Do yourself a favor and replace ALL of them while it is out. I also like to remove the block drain plugs and install petcocks so future draining of the block is easier. Yeah, no reason to take a chance on the driver side
Abe Lincoln
[Re: dvw]
#2197643
11/16/16 11:35 PM
11/16/16 11:35 PM
dart4forte
Mesa, Arizona
Are they leaking between the plug and block or are the rusted through from the back side? Doug Leaking between the plug and the block
Abe Lincoln
[Re: dart4forte]
#2197671
11/16/16 11:53 PM
11/16/16 11:53 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Were they dry on install? A few here will know better than me but I have always used the Indian Head Shellac on soft plugs...brass or steel... Don't be afraid to just pull the K frame...I think its actually easier...
...FAFO...
[Re: dart4forte]
#2197672
11/16/16 11:54 PM
11/16/16 11:54 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Mix up some alumaseal in a cup with some water, pour the mixture in there and drive it for the rest of the winter. Drop the motor out from the bottom in the spring and replace all those plugs.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Belvedere1]
#2197704
11/17/16 12:27 AM
11/17/16 12:27 AM
dart4forte
Mesa, Arizona
I was planning a trip up to WA state next month. May load it up and take it with me. I'll have a hoist where we can drop everything out the bottom.
Abe Lincoln
[Re: Belvedere1]
#2197706
11/17/16 12:30 AM
11/17/16 12:30 AM
dart4forte
Mesa, Arizona
I'm available to lend a hand if you decide to tackle it. Hey, thanks for the offer. I was under the car this afternoon. The only plug assessable is the center. The rear plug is blocked by the exhaust manifold. The front plug is blocked by the motor mount.
Abe Lincoln
