Re: lifter valley plate for trick flows
[Re: Jimbo]
#2184924
10/28/16 10:22 PM
10/28/16 10:22 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Trying to be helpful... The valley breather is a tough nut to crack. A lot of oil in suspension there. You need a large amount of well thought out baffling to succeed. Also, with any breather, the larger the inner diameter of the exit tube, the lower the velocity. Velocity is the common culprit of oil escaping from breathers.
[Re: Jimbo]
#2194601
11/11/16 10:37 AM
11/11/16 10:37 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Looks Great Andy! How did the valley breather work out?
Are the Batwings also available? Standard and/or MW port?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
