Has anyone seen this on a block? #2192444
11/08/16 10:19 PM
11/08/16 10:19 PM
Western New York
sixpackbee Offline OP
Western New York
Getting the pilot Formula S ready for MCACN and looked at the original block. It is cracked so a replacement is in the car until I can get the numbers block fixed. Anyhow, there is a plate welded over the place where the vin is stamped. That plate is stamped with the vin. The engine was assembled June 13 1968. I would love to see what is under that plate. Anyone seen this before?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192474
11/08/16 11:00 PM
11/08/16 11:00 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Crazy, never saw anything like that before..... eek
Admiration For Multiple Carburetor Vehicles...
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192475
11/08/16 11:01 PM
11/08/16 11:01 PM
MO
cdp Offline
cdp  Offline
MO
very strange. Possible a replacement block and dealership "transferred" stampings. Wow, super low serial number.
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192481
11/08/16 11:07 PM
11/08/16 11:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Never seen that. Looks like there is not a machined surface behind it.
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192526
11/09/16 12:12 AM
11/09/16 12:12 AM
Washington/Las Vegas
1971 Gran Coupe Offline
Maybe Scott from Harms will chime in on this one, oh and Barry too!
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192554
11/09/16 12:41 AM
11/09/16 12:41 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cool to see.
Can you get overall pics of both block sides?
Re: Has anyone seen this on a block? [Re: Alaskan_TA] #2192566
11/09/16 12:58 AM
11/09/16 12:58 AM
Western New York
Western New York
Will do tomorrow when I am back in the shop.
1959 Bugeye Sprite
1971 MG Midget
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192579
11/09/16 01:19 AM
11/09/16 01:19 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A clear shot of the VIN on the transmission would be great to.
Re: Has anyone seen this on a block? [Re: sixpackbee] #2192595
11/09/16 01:29 AM
11/09/16 01:29 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have not seen one like that, but with a pre-production/pilot/first day of production, or otherwise "oddball" car, anything is possible.
Re: Has anyone seen this on a block? [Re: ScottSmith_Harms] #2192640
11/09/16 02:05 AM
11/09/16 02:05 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
As Arte Johnson used to say, VELLY INTELLESTING! scope
JB Rhinehart, Realist
A-Body's RULE!
Re: Has anyone seen this on a block? [Re: Alaskan_TA] #2194097
11/10/16 05:47 PM
11/10/16 05:47 PM
Western New York
Western New York
Barry, Here are the block shots. Trans can't be done. There are headers on the car and they prevent a good shot. The numbers are and as spaced: 28 92089 2440.
1959 Bugeye Sprite
1971 MG Midget
Re: Has anyone seen this on a block? [Re: sixpackbee] #2194167
11/10/16 07:16 PM
11/10/16 07:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
can you tell if the VIN stamped piece is cast? hardness test?
it looks like someone took the VIN stamped piece of the original block, machined & ground it down to fit the proper area then brazed it to another block.
based on the dates it could've been done early in the car's life, possibly before it left Chrysler
Re: Has anyone seen this on a block? [Re: 6bblgt] #2194187
11/10/16 08:01 PM
11/10/16 08:01 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have had a few 6-22-67 340 blocks, that must be the initial casting date? shruggy For sure it wouldn't have the machined pad, that didn't start until 1969. I have never seen a numbers 69 block using that early casting date. Dan it probably right. twocents
A-Body's RULE!
Re: Has anyone seen this on a block? [Re: sixpackbee] #2194190
11/10/16 08:03 PM
11/10/16 08:03 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Looks to me like they had an early cast block that did not have the raised pad by the pan rail so the grabbed a piece of flat stock, stamped it and welded it in place. Looks like sometime Chrysler would have done to me b
Re: Has anyone seen this on a block? [Re: sixpackbee] #2194202
11/10/16 08:17 PM
11/10/16 08:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Looking at the first two photos, I do not see room for a VIN pad underneath the plate, the pad does stick out.
Can you get a clear, close up photo from the bottom that would show any gap (or none) behind the plate ?
What I see is that it sits on the block.
Check the top of the bellhousing flange near for any stamped numbers also just for fun.
Re: Has anyone seen this on a block? [Re: sixpackbee] #2194203
11/10/16 08:22 PM
11/10/16 08:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Give the pad a cleaning with a rust remover also.
It is a blurry image but I do not see the normal cutter swirls on the face of the plate that would support the 'removed from another block theory', but a cleaner pad would tell the tale.
So clean it up & get a clear closeup please?
Re: Has anyone seen this on a block? [Re: fastmark] #2194226
11/10/16 08:57 PM
11/10/16 08:57 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
BOOM...
Re: Has anyone seen this on a block? [Re: Stewpar] #2194233
11/10/16 09:04 PM
11/10/16 09:04 PM
Western New York
Western New York
It is just a piece of flat stock. It does not look like there is the raised area under it either.
1959 Bugeye Sprite
1971 MG Midget
