Lost Oil Pressure - What to Do? #2192369
11/08/16 08:32 PM
11/08/16 08:32 PM
Chicago
PurpleBeeper Offline OP
Chicago
I was driving home and had pulled up in front of my house (at idle) and heard "rattle, rattle" (440 engine) & saw my oil pressure had dropped to zero, so I shut the motor off. Thank God I was in front of my house. It sounded like the valve gear rattling & not the deep "clunk, clunk" of a rod/main bearing (I'm hoping anyway). The engine did not seem to have any type of misfire.
These are the things that I can think of that could cause this problem.
1. spun main bearing
2. spun rod bearing
3. spun cam bearing (#4, right?)
4. leaking line going to the oil pressure gage
5. oil pump failure
6. REALLY low oil (was 1-1/2 qts. low per aftermarket dipstick). I don't think the pickup sucks air until about 3 qts. low (?)
7. Oil pump failure
8. sheared off the hex end of the oil pump/distributor gear
I'm afraid to even crank the motor until I find the problem. Obviously I don't want to pull the engine if I don't have to.
How do you guys suggest I go about fixing this problem? What order should I check everything? Can I see the hex end of the distributor/oil pump drive if I just pull the pump off? How can I tell if the pump went bad?
Any help is appreciated. Thanks in advance.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192373
11/08/16 08:40 PM
11/08/16 08:40 PM
Kirkland, Washington
Pacnorthcuda Offline
I'd start by pulling the distributor and intermediate shaft. If they look good then spin the pump with hex and drill while checking for pressure.
If none then I'd pull the pump and disassemble. I had a stuck pressure relief valve on a small block pump once so look at that portion carefully.
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192374
11/08/16 08:40 PM
11/08/16 08:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Had #8 happen to me once on a 360.
You can pull the pump, or pull the distributor and rotate the drive out. Easier to do on a 440 than a 360.
Don't be the exception.
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192375
11/08/16 08:42 PM
11/08/16 08:42 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
verify the drive, fill with oil and start!
On a big block I had a pump go bad, took out a crank, just that fast.
Relief spring stuck open because of RTV a previous owner had applied to valve covers, I do not use RTV, never have, never will.
Have a great day
Iowan
"obsolete is neat"
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192380
11/08/16 08:48 PM
11/08/16 08:48 PM
Did you ever calibrate the after market dipstick to your oil pan? If not drain the oil pan now and look at the oil for shiny metal flakes and measure how much comes out and compare that to what the dipstick shows now before you drain it, that will answer your question on how much it has in it now.
While you have the drain plug out look inside at the pickup and see how far it is above the top of the drain plug hole or if it is sitting on the bottom of the oil pan like Ma Mopar suggests to set them up at in the factory service manuals scope
As far as what caused the loss of oil pressure may be answered by looking at the oil in the drain pan and the height of the oil pickup now work If it is not a oil starvation problem due to oil level then take the oil pump off and remove the bypass plug and see if the bypass valve is free or stuck inside it, if stuck that is your problem, if not stuck see if the oil pump drive shaft tip is broken off and stuck in the oil pump gear drive hole scope
Do these things now and let us know what you find up
Re: Lost Oil Pressure - What to Do? [Re: Cab_Burge] #2192388
11/08/16 08:59 PM
11/08/16 08:59 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Bent push rod.
Lifter popped out of it's bore.
Pull the valve covers.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Lost Oil Pressure - What to Do? [Re: hemi71x] #2192394
11/08/16 09:07 PM
11/08/16 09:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By hemi71x
Bent push rod.
I had that happen on a 400.
Damn, I'm a jinx
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192430
11/08/16 09:55 PM
11/08/16 09:55 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Do an oil change and cut the filter. Definitely start up top. Pull the dis. and int. shaft. Pull the valve covers and make sure everything is good. Spin the pump(counterclockwise). No pressure? Lastly pull the oil pump if all is well up top.
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192514
11/08/16 11:55 PM
11/08/16 11:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cut the filter before anything. Look OK? Check to see if the hex broke on the oil pump drive? If so the pump rotors are are probably jammed, determin the source of the debris.
Doug
Re: Lost Oil Pressure - What to Do? [Re: Pacnorthcuda] #2192525
11/09/16 12:09 AM
11/09/16 12:09 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Do not forget the BB distributors / oil pump drives rotate CCW.
If you cannot get oil pressure, next step is to remove the valve covers and look for the potential problem. IE: broken rocker, other valve train issue that may have allowed a lifter to exit its bore. Next stop, Oil pump itself. DO NOT start the motor until the issue is identified. The drill motor is your friend twocents
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192855
11/09/16 09:33 AM
11/09/16 09:33 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
In 1975 my 383 pump failed just south of 80,000 miles, at startup, I let it run just a hair too long and developed terminal knock.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2192964
11/09/16 12:42 PM
11/09/16 12:42 PM
an8sec70cuda Offline
The first thing I'd do is pull the valve covers and look for a pushrod out of place. If there is one that's out of place, look to see if the lifter popped out...that will kill your oil pressure and probably not hurt the motor at all otherwise. Obviously you need to find out why the pushrod got loose...rocker adjuster issue, cam lobe going flat, etc.
If all is good under the valve covers, pull the distributor and check the oil pump driveshaft. It may be broken. If it is, pull the oil pump off and inspect it.
Then I'd drain the oil, check for glitter in it, and cut open the oil filter.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Lost Oil Pressure - What to Do? [Re: hemi71x] #2196187
11/14/16 02:34 PM
11/14/16 02:34 PM
milwaukee
superbird Offline
superbird  Offline
milwaukee
Bent push rod.
had a sticky valve cause this
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2226296
01/03/17 02:00 PM
01/03/17 02:00 PM
Chicago
Chicago
I got VERY LUCKY.... thank you God. It was #6 & I shut the motor off in time.
The dipstick (aftermarket) was about 1 qt. off & I calibrated it when I changed the oil. I was at least 2-1/2 qts. low on oil (likely 3 qts. low) and the pickup sucked air for about 20 seconds.
Re: Lost Oil Pressure - What to Do? [Re: PurpleBeeper] #2226302
01/03/17 02:13 PM
01/03/17 02:13 PM
what I do is have the car level. add 4 qts (for a std 4 qt sump pan) from scratch. mark the stick full at that point. this takes the filter out of the equation & this is with it previously primed so the passages everything is filled
