Lost Oil Pressure - What to Do?
#2192369
11/08/16 08:32 PM
11/08/16 08:32 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I was driving home and had pulled up in front of my house (at idle) and heard "rattle, rattle" (440 engine) & saw my oil pressure had dropped to zero, so I shut the motor off. Thank God I was in front of my house. It sounded like the valve gear rattling & not the deep "clunk, clunk" of a rod/main bearing (I'm hoping anyway). The engine did not seem to have any type of misfire.
These are the things that I can think of that could cause this problem. 1. spun main bearing 2. spun rod bearing 3. spun cam bearing (#4, right?) 4. leaking line going to the oil pressure gage 5. oil pump failure 6. REALLY low oil (was 1-1/2 qts. low per aftermarket dipstick). I don't think the pickup sucks air until about 3 qts. low (?) 7. Oil pump failure 8. sheared off the hex end of the oil pump/distributor gear
I'm afraid to even crank the motor until I find the problem. Obviously I don't want to pull the engine if I don't have to.
How do you guys suggest I go about fixing this problem? What order should I check everything? Can I see the hex end of the distributor/oil pump drive if I just pull the pump off? How can I tell if the pump went bad?
Any help is appreciated. Thanks in advance.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Lost Oil Pressure - What to Do?
[Re: PurpleBeeper]
#2192374
11/08/16 08:40 PM
11/08/16 08:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Had #8 happen to me once on a 360.
You can pull the pump, or pull the distributor and rotate the drive out. Easier to do on a 440 than a 360.
[Re: PurpleBeeper]
#2192375
11/08/16 08:42 PM
11/08/16 08:42 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
verify the drive, fill with oil and start!
On a big block I had a pump go bad, took out a crank, just that fast.
Relief spring stuck open because of RTV a previous owner had applied to valve covers, I do not use RTV, never have, never will.
Have a great day Iowan
"obsolete is neat"
[Re: PurpleBeeper]
#2192380
11/08/16 08:48 PM
11/08/16 08:48 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
Did you ever calibrate the after market dipstick to your oil pan? If not drain the oil pan now and look at the oil for shiny metal flakes and measure how much comes out and compare that to what the dipstick shows now before you drain it, that will answer your question on how much it has in it now. While you have the drain plug out look inside at the pickup and see how far it is above the top of the drain plug hole or if it is sitting on the bottom of the oil pan like Ma Mopar suggests to set them up at in the factory service manuals As far as what caused the loss of oil pressure may be answered by looking at the oil in the drain pan and the height of the oil pickup now If it is not a oil starvation problem due to oil level then take the oil pump off and remove the bypass plug and see if the bypass valve is free or stuck inside it, if stuck that is your problem, if not stuck see if the oil pump drive shaft tip is broken off and stuck in the oil pump gear drive hole Do these things now and let us know what you find
[Re: hemi71x]
#2192394
11/08/16 09:07 PM
11/08/16 09:07 PM
Supercuda
About to go away
About to go away
up yours
Bent push rod. Lifter popped out of it's bore. Pull the valve covers.
I had that happen on a 400. Damn, I'm a jinx
[Re: PurpleBeeper]
#2192855
11/09/16 09:33 AM
11/09/16 09:33 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
In 1975 my 383 pump failed just south of 80,000 miles, at startup, I let it run just a hair too long and developed terminal knock.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: PurpleBeeper]
#2192964
11/09/16 12:42 PM
11/09/16 12:42 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
The first thing I'd do is pull the valve covers and look for a pushrod out of place. If there is one that's out of place, look to see if the lifter popped out...that will kill your oil pressure and probably not hurt the motor at all otherwise. Obviously you need to find out why the pushrod got loose...rocker adjuster issue, cam lobe going flat, etc.
If all is good under the valve covers, pull the distributor and check the oil pump driveshaft. It may be broken. If it is, pull the oil pump off and inspect it.
Then I'd drain the oil, check for glitter in it, and cut open the oil filter.
[Re: hemi71x]
#2196187
11/14/16 02:34 PM
11/14/16 02:34 PM
Posts: 386 milwaukee
superbird
milwaukee
had a sticky valve cause this
[Re: PurpleBeeper]
#2226296
01/03/17 02:00 PM
01/03/17 02:00 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I got VERY LUCKY.... thank you God. It was #6 & I shut the motor off in time.
The dipstick (aftermarket) was about 1 qt. off & I calibrated it when I changed the oil. I was at least 2-1/2 qts. low on oil (likely 3 qts. low) and the pickup sucked air for about 20 seconds.
[Re: PurpleBeeper]
#2226302
01/03/17 02:13 PM
01/03/17 02:13 PM
RapidRobert
what I do is have the car level. add 4 qts (for a std 4 qt sump pan) from scratch. mark the stick full at that point. this takes the filter out of the equation & this is with it previously primed so the passages everything is filled
