Thrust block, Pin, or button removal #2192133
11/08/16 12:51 PM
11/08/16 12:51 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
I am told that I am pre-loading my green bearings because of rear end housing is 1/8 narrower than stock and I must remove the thrust thing that's in there. I need info on a direction to take on the removal of this thrust thing or can I shorten these axles.
Re: Thrust block, Pin, or button removal [Re: JL2] #2192149
11/08/16 01:31 PM
11/08/16 01:31 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Eaton customer service told me to get a long pair of needle nose pliers and yank them out. This advice was for a Detroit Locker in an 8-3/4" 742 housing.
Re: Thrust block, Pin, or button removal [Re: JL2] #2192165
11/08/16 02:02 PM
11/08/16 02:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It depends on what style sure-grip you have. The cone sure-grips and stock 489/741 open cases are going to be a PITA.(not sure about open 742 cases) Just a couple weeks ago I tried removing the thrust block from an open 741 case. I tapped out the roll pin and tried to remove the shaft so the thrust block would come out. The shaft hits the ring gear. I guess the ring gear needs to be removed first. Luckily I did some measuring and I had just enough clearance so I could mock up the rear end while leaving the thrust block in place. When I rebuild the center section, I'll remove it for good.
If you have a clutch style sure-grip, you should be able to remove the button with a punch.
Re: Thrust block, Pin, or button removal [Re: JL2] #2192185
11/08/16 02:47 PM
11/08/16 02:47 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
I have the clutch type power lock in a 489 case. I can't find any info on what it even looks like. The good thing is that the third member is on my work bench. I just don't know what I'm lookin for.
Re: Thrust block, Pin, or button removal [Re: JL2] #2192203
11/08/16 03:14 PM
11/08/16 03:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
http://www.moparts.org/Tech/Archive/axle/13.html
Lots of great info in the tech archives. The above link has a picture of the thrust button you need to remove.
Re: Thrust block, Pin, or button removal [Re: JL2] #2192220
11/08/16 03:42 PM
11/08/16 03:42 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Just happened to have mine on the bench to replace the clutches. This is a 742 unit. However the pins are the same and look like this.
And they are located here in the center of the diff:
You can remove them by using a punch or by just reaching in with a pair of needle nose pliers and pulling them out. If they're stuck you'll need to use the punch.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Thrust block, Pin, or button removal [Re: burdar] #2192222
11/08/16 03:44 PM
11/08/16 03:44 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Thanks man, I'm gonna take a look at that when I get home to see what it takes to get them out.
Re: Thrust block, Pin, or button removal [Re: Centerline] #2192275
11/08/16 05:28 PM
11/08/16 05:28 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Thank You for the info..
