Re: Thrust block, Pin, or button removal
[Re: JL2]
#2192220
11/08/16 03:42 PM
11/08/16 03:42 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Just happened to have mine on the bench to replace the clutches. This is a 742 unit. However the pins are the same and look like this. And they are located here in the center of the diff: You can remove them by using a punch or by just reaching in with a pair of needle nose pliers and pulling them out. If they're stuck you'll need to use the punch.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
