Re: High 10 second A body Gen III build. Any out there?
[Re: cudadoug]
#2176445
10/16/16 10:29 PM
10/16/16 10:29 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I ran a 12.07@ 121.75, 1.99 60ft. 3700lbs. Really wish I had some slicks. I have CNC'd 6.1 heads with 2.10 intakes. I would skip the 5.7 heads unless they are Eagles and are worked on. The capability of the heads is the main reason I did a Gen III to begin with. Dont mess with the older 5.7 heads, waste of money when if you keep your ear to the ground, Eagles, Apaches and 6.1's are ready for the stealing. 6.1's seem to be thrown to the side these days but if you find a good used set, you start with 2.08" hollow stem intakes and 1.62 hollow exhausts. [ Moparts Family Site - Keep it Friendly ] is not to like there?
Mopar to the bone!!!
[Re: 72Swinger]
#2176838
10/17/16 01:21 PM
10/17/16 01:21 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I ran a 12.07@ 121.75, 1.99 60ft. 3700lbs. Really wish I had some slicks. I have CNC'd 6.1 heads with 2.10 intakes. I would skip the 5.7 heads unless they are Eagles and are worked on. The capability of the heads is the main reason I did a Gen III to begin with. Dont mess with the older 5.7 heads, waste of money when if you keep your ear to the ground, Eagles, Apaches and 6.1's are ready for the stealing. 6.1's seem to be thrown to the side these days but if you find a good used set, you start with 2.08" hollow stem intakes and 1.62 hollow exhausts. [ Moparts Family Site - Keep it Friendly ] is not to like there? Yes, after speed reading last night I see where the 5.7 heads are a waste of time based on those Eagle and Appache versions! I was toying with a Gen III project a few years ago when the Eagle was available cheap from Mopar and almost got a set then, but didn't pull the trigger due to too many other things going on...DOH! How is reliability with hollow stem valves?
[Re: cudadoug]
#2178631
10/19/16 03:20 PM
10/19/16 03:20 PM
Posts: 112 Michigan
ghinmi
You should be able to run high 10s easy in an A-body with a stock Eagle 5.7 and a little bit of boost. Mine's not an A-body but it's 3995 lbs and has run 11.46 @ 120 on only 6 psi. 93 octane and air/air intercooled. Super low dollar setup and I drive the heck out of it. Drag week, long cruises, daily driving, etc. 3.64 gears and a 6 speed.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: cudadoug]
#2180690
10/23/16 02:44 AM
10/23/16 02:44 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
How is reliability with hollow stem valves? The OEM valves are not meant for much rpm or spring pressure...this comes right from Ferrea. I haven't run the Manley hollow stems so I can't say for sure. Brian
Brian Hafliger
[Re: Brian Hafliger]
#2184997
10/28/16 11:43 PM
10/28/16 11:43 PM
cudadoug
How is reliability with hollow stem valves? The OEM valves are not meant for much rpm or spring pressure...this comes right from Ferrea. I haven't run the Manley hollow stems so I can't say for sure. Brian I kinda figured. Don't think I'd want to risk it even in a mild build like I'm contemplating.
[Re: cudadoug]
#2185112
10/29/16 03:34 AM
10/29/16 03:34 AM
72Swinger
Nebraska
What is too much spring? 370 lbs open?
[Re: cudadoug]
#2191907
11/08/16 12:09 AM
11/08/16 12:09 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are interested in an easy path to decent power, Ma Mopar just announced 392 485 hp crate motors and install kit (computer, wiring,etc) for MSRP of about 11,500 for both motor and kit. I would guess you could get it cheaper by a couple of thou? There are a lot of advantages in going with a factory motor that was pulled off the regular engine line. Add in a good header and exhaust system, and it ought to be close to your goal. Ask around what the true cost is of a custom engine build and everything needed to match what you get with the crate motor, might be a cost effective way to go Plus the mileage , low speed torque and reliability will be excellent.
[Re: gregsdart]
#2192364
11/08/16 08:13 PM
11/08/16 08:13 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
If you are interested in an easy path to decent power, Ma Mopar just announced 392 485 hp crate motors and install kit (computer, wiring,etc) for MSRP of about 11,500 for both motor and kit. I would guess you could get it cheaper by a couple of thou? There are a lot of advantages in going with a factory motor that was pulled off the regular engine line. Add in a good header and exhaust system, and it ought to be close to your goal. Ask around what the true cost is of a custom engine build and everything needed to match what you get with the crate motor, might be a cost effective way to go Plus the mileage , low speed torque and reliability will be excellent. Whats a good running Scatpack Challenger running? Hight 11s? At 4400 lbs take 1000lbs out and high 10's? good converter, long tube and gears. Matt
[Re: cudadoug]
#2199298
11/20/16 11:20 AM
11/20/16 11:20 AM
Posts: 720 apache junction, az
rtsinc
apache junction, az
hi guys, not sure what this cuda will do when finally streetable. whipple supercharged 6.4 crate hemi built by arringtons. backed by a small block 727 auto. dyno at just over 800 hp. 3 inch tti exhaust, has a/c, installed in a 70 cuda body. all creature comforts. heated and power seats, tilt column, alpine stereo, uconnect, 4 wheel disc, rack and pinion, new tech dash RTS RESTOS DAY GLO CLUSTER. 3:55 gears, moser axles, randys chunk, and much more....
[Re: rtsinc]
#2200147
11/21/16 07:51 PM
11/21/16 07:51 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
hi guys, not sure what this cuda will do when finally streetable. whipple supercharged 6.4 crate hemi built by arringtons. backed by a small block 727 auto. dyno at just over 800 hp. 3 inch tti exhaust, has a/c, installed in a 70 cuda body. all creature comforts. heated and power seats, tilt column, alpine stereo, uconnect, 4 wheel disc, rack and pinion, new tech dash RTS RESTOS DAY GLO CLUSTER. 3:55 gears, moser axles, randys chunk, and much more.... Just ease into the throttle when you go for your first ride, because if you put sticky tires on that beast you will quickly find the weak link in your driveline. I would love to be there when you do it
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: cudadoug]
#2202785
11/26/16 10:39 AM
11/26/16 10:39 AM
gregsdart
rtsinc, Have you considered an OD trans ? I know it is another hit in the wallet, but the revs with a 1/1 high gear will be 3000+ on the freeway and the noise might be be a little bothersome, along with poor gas mileage. Hughes has a lockup GM trans that will hold the torque. Not sure if they have the matching bellhousing for the Hemi, but if they do that is one stout trans.
[Re: cudadoug]
#2202868
11/26/16 03:39 PM
11/26/16 03:39 PM
72Swinger
Nebraska
4L80E would work wonders in that combo, but so would a NAG1.
[Re: 72Swinger]
#2204320
11/29/16 11:08 AM
11/29/16 11:08 AM
gregsdart
4L80E would work wonders in that combo, but so would a NAG1. Hmmmmm, that is worth a comparison post,,,
