Re: Want to go from a 850 to a 1050? is this a good idea?
[Re: DRBNSB]
#2190924
11/06/16 09:08 PM
11/06/16 09:08 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Nope if it's a good carb.. you'll be a happy camper
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: DRBNSB]
#2190946
11/06/16 09:30 PM
11/06/16 09:30 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I have a 950 on my dinky 318. I put a 750 on it and it slowed the car down better than a tenth. I only shift this thing at 6200, trap at 5900-6000. I figured the 750 would be better against advice on here. They were right.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: DRBNSB]
#2190989
11/06/16 10:17 PM
11/06/16 10:17 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I had an 850 Proform on our 10.8 to 1 360 magnum with 2.02 ported MP mag R/T heads, Indy single plane, and Hughes 238/242 hyd. Roller. Swapped to an annular 1050 proform main body and picked up over 3 tenths and almost 3 mph. I'd say try it and you should see some sizable gains also.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: DRBNSB]
#2190994
11/06/16 10:23 PM
11/06/16 10:23 PM
Quicktree
I have recently gotten a small block 360 72 dart drag car. Runs solid 6.80'in the eighth It has a Holley pro form 850 on it now. Runs good. But with 13.1 compression. I am thinking about going e85. I have the e85 1050 dominator already. Would this be to much carb for this combo? it turns 7500rpm I typically shift at 6500 though. Thanks. it should work fine, I have a nice FAST E85 wide band system i'll sell you , will make the learning curve a little easier.
