Want to go from a 850 to a 1050? is this a good idea? #2190916
11/06/16 08:55 PM
11/06/16 08:55 PM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
I have recently gotten a small block 360 72 dart drag car. Runs solid 6.80'in the eighth It has a Holley pro form 850 on it now. Runs good. But with 13.1 compression. I am thinking about going e85. I have the e85 1050 dominator already. Would this be to much carb for this combo? it turns 7500rpm I typically shift at 6500 though. Thanks.
Re: Want to go from a 850 to a 1050? is this a good idea? [Re: DRBNSB] #2190924
11/06/16 09:08 PM
11/06/16 09:08 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Nope if it's a good carb.. you'll be a happy camper
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Want to go from a 850 to a 1050? is this a good idea? [Re: DRBNSB] #2190946
11/06/16 09:30 PM
11/06/16 09:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a 950 on my dinky 318. I put a 750 on it and it slowed the car down better than a tenth.
I only shift this thing at 6200, trap at 5900-6000.
I figured the 750 would be better against advice on here. They were right.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Want to go from a 850 to a 1050? is this a good idea? [Re: DRBNSB] #2190989
11/06/16 10:17 PM
11/06/16 10:17 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I had an 850 Proform on our 10.8 to 1 360 magnum with 2.02 ported MP mag R/T heads, Indy single plane, and Hughes 238/242 hyd. Roller. Swapped to an annular 1050 proform main body and picked up over 3 tenths and almost 3 mph. I'd say try it and you should see some sizable gains also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Want to go from a 850 to a 1050? is this a good idea? [Re: DRBNSB] #2190994
11/06/16 10:23 PM
11/06/16 10:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it should work fine, I have a nice FAST E85 wide band system i'll sell you , will make the learning curve a little easier.
Re: Want to go from a 850 to a 1050? is this a good idea? [Re: DRBNSB] #2190997
11/06/16 10:27 PM
11/06/16 10:27 PM
Washington
madscientist Offline
Washington
Needs a dominator.
