Re: Mopar is making a retrofit kit!
[Re: WO23Coronet]
#2196341
11/14/16 06:54 PM
11/14/16 06:54 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
Is this for the VVT or the earlier engines and does it do the MDS stuff?
[Re: WO23Coronet]
#2196587
11/15/16 01:29 AM
11/15/16 01:29 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
They could be manual trans engines without MDS so they can be used with any trans. That would make more sense.
Mopar to the bone!!!
[Re: 72Swinger]
#2196664
11/15/16 11:00 AM
11/15/16 11:00 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
They could be manual trans engines without MDS so they can be used with any trans. That would make more sense. You are correct. Right from allpar. The unlocked factory PCM has a custom calibration; the Mopar 345 Crate Hemi Engine Kit bumps horsepower to 383 and torque to 425 lb.ft. for the 5.7-liter (well above production stock), while the 392 Crate Hemi Engine Kit keeps the 6.4 at 485 horses and 472 lb.ft. of torque. The engines are designed for manual transmissions; automatic transmissions, such as the Torqueflite 727 and 904, while not optimal, can also be adapted. Need to read before I post!
[Re: WO23Coronet]
#2197407
11/16/16 04:57 PM
11/16/16 04:57 PM
Posts: 3 MICHIGAN
Driftacular
MICHIGAN
The kit works with 2013+ engines! MattW is very right, the crank target wheel and sensor is different 2012 and prior.
what else is different on a older engine, I'm not sure.
No MDS btw.
As for the canadian prices... find a place that will give you some percent off.. price is MSRP. already seeing it online for cheaper, like 1560$ USD. Thats 2093$ CAD today..
[Re: MattW]
#2199201
11/20/16 12:42 AM
11/20/16 12:42 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Called mopar performance and they said its unlocked. Diablo and away you go! This could be the answer to many problems with retrofitting this engine. Matt What is a Diablo?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#2199204
11/20/16 12:48 AM
11/20/16 12:48 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Called mopar performance and they said its unlocked. Diablo and away you go! This could be the answer to many problems with retrofitting this engine. Matt What is a Diablo? Handheld tuner that you can load flash tunes onto. You may be able to tune on-the-fly with it?
[Re: WO23Coronet]
#2200022
11/21/16 04:34 PM
11/21/16 04:34 PM
HotRodDave
Kalispell Mt.
I thought the 5.7 was making 395 in the newer trucks, 345 was the 03-08 rating? Seems if it is for the newer truck engine (most redily available of the 2013+ engine) it will make less HP not more... I am confused
[Re: WO23Coronet]
#2200813
11/22/16 10:11 PM
11/22/16 10:11 PM
Posts: 4,269 Canada
WO23Coronet
Canada
The ram 5.7 has a different intake that's supposed to make better power, but I suspect it's a lot of "pen and paper dyno numbers". I think besides the intake they're the same motor (cam, heads, compression etc)
[Re: WO23Coronet]
#2200816
11/22/16 10:15 PM
11/22/16 10:15 PM
MattW
Ontario Canada
The ram 5.7 has a different intake that's supposed to make better power, but I suspect it's a lot of "pen and paper dunk numbers". I think besides the intake they're the same motor (cam, heads, compression etc) Don't know why its only 383 hp and the new ram is 395. Can't be the intake on the ram cuz they use a variable intake on the 6.4. So they should be able to do the ram also? Matt
[Re: WO23Coronet]
#2201045
11/23/16 04:57 AM
11/23/16 04:57 AM
72Swinger
Nebraska
I think the truck intake is variable runner as well.
[Re: WO23Coronet]
#2201532
11/24/16 12:05 AM
11/24/16 12:05 AM
HotRodDave
Kalispell Mt.
I have a 2011 ram 5.7 intake here and it is variable
[Re: GoodysGotaCuda]
#2293237
04/24/17 02:26 PM
04/24/17 02:26 PM
Posts: 106 MI.
mech440
MI.
I called Diablo today as I'm almost ready to start my 6.4 and I bought the mopar crate wiring and computer kit. Diablo stated that they do not have anything that support this PCM? I was told that the PCm is umlocked but their software may "re-lock it"
I'm not sure if the guy knew what he was talking about... anyone else have any input on this issue?? Thanks.
Mech
If it doesn't have a motor.....it's not a REAL sport
[Re: WO23Coronet]
#2296051
04/29/17 01:02 PM
04/29/17 01:02 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
Pushed like hell for MP to sell that 2006-7-8-9-10-11-12 and 13.
Multiple lists of part numbers created by my coworkers, countless emails and discussions why it would be a great idea, hours and hours spent trying to convince people, etc.
Better late than never, right?
In the time between '13 and today, how many customers got tired of waiting and went the LS route? Only a couple, right? LOLzz
Rich H.
Esse Quam Videri
