Which shocks to use? 68 Dart with SS springs #2187783
11/01/16 11:55 PM
11/01/16 11:55 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Looking for shock advice. I have a 1968 Dodge Dart that has SS springs and and inboard kit. I have a set of Monroe shocks for an 1986 Dodge D150 I think will work.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188249
11/02/16 07:52 PM
11/02/16 07:52 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Some 1/2-ton shocks are the same as the C-body rears; if you compare them to the stock Dart rear shocks they should have quite a bit more travel. Might even be longer, it's been a long time since I've seen a stock rear Mopar shock.
The point is that when the SS springs arch at the hit, they don't top out the shock.
No doubt the aftermarket adjustable shocks are better, but I've been low 10s on used stock shocks.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188256
11/02/16 08:01 PM
11/02/16 08:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I used C-body and truck shocks,but finally went with Rancho 9000 series and they made a world of difference.
Nautilus Racing-
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188270
11/02/16 08:17 PM
11/02/16 08:17 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I just relocated the springs on my 67 barracuda and was wondering which shocks to use.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188323
11/02/16 09:26 PM
11/02/16 09:26 PM
Washington
madscientist Offline
Washington
For a bit more money, a QA-1 or Viking double adjustable will be miles ahead.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188461
11/03/16 12:21 AM
11/03/16 12:21 AM
PA
ajcasini Offline
ajcasini  Offline
PA
I would agree with the above the Viking shock would make a world of difference.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188462
11/03/16 12:23 AM
11/03/16 12:23 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
How fast is this car? Anything much quicker than a basic driver is going to benefit from something other than a truck shock
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188654
11/03/16 12:25 PM
11/03/16 12:25 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Make sure you measure for the right size shocks. I use Competition Engineering. They work ok for a 11 second car and the price is not bad.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188681
11/03/16 01:08 PM
11/03/16 01:08 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I tried the truck Monroematics on my '67 Satellite with SS springs. It would 60 foot pretty decent for what it is (1.68 to 1.72 running 7.90s in the 1/8) with them using bias ply slicks but when I switched to drag radials it would hook and then unload about 50 feet out and my 60 foot times would be all over the place.
When I took them off to replace them with some Competition Engineering drag shocks I noticed that the Monroes extended and compressed more like they were a 90/10 shock. The Competition Engineering drag shocks got my 60 foot times back where they were and they ride and handle way better on the street too.
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188916
11/03/16 07:17 PM
11/03/16 07:17 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My best with rancho 9 ways was 1.43, changed to afco doubles improved to 1.36.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Which shocks to use? 68 Dart with SS springs [Re: Chryco69] #2188934
11/03/16 07:51 PM
11/03/16 07:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Had 002/003 leafs on my old car. Weighed 3350.
Used the simple Comp eng 3 ways on the back. Car went 1.34 with them, and from outing to outing was very consistent.
I doubt another shock would have shown any gain. It dead hooked everywhere.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
