Junkyard magnum record #2187776
11/01/16 11:47 PM
11/01/16 11:47 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Got a magnum from the junkyard in my sons duster, went 11.22
....BAD A$$ STREET CAR.....
Re: Junkyard magnum record [Re: n20mstr] #2187785
11/01/16 11:56 PM
11/01/16 11:56 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
OH wait , it went 11.15 , but we tried to slow it down some....forgot that
Re: Junkyard magnum record [Re: n20mstr] #2187787
11/02/16 12:03 AM
11/02/16 12:03 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I think that's doing damn good. I saw a shirt box Dakota drifting this weekend, was actually doing well
Re: Junkyard magnum record [Re: SpareParts] #2187877
11/02/16 03:35 AM
11/02/16 03:35 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
So tell us more. What's done to that junkyard dawg??
Re: Junkyard magnum record [Re: n20mstr] #2188404
11/02/16 11:15 PM
11/02/16 11:15 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
4 mods to a stock magnum,
1 nitrous plate with 52n 47 fuel
2 intake with 650 carb
3 Scott brown cam
4 changed pushrods and oil pan
That's it, never took the heads off, reused the lifters and all the stock valvetrain.
Re: Junkyard magnum record [Re: n20mstr] #2188431
11/02/16 11:40 PM
11/02/16 11:40 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
IMHO they are one of the best bang for the buck options out there. We have one in a 3300 lb Dakota that runs mid 11's with not much at all done to it. I just dingle berry honed it, added a set of std. KB 107s, hughes hyd. roller cam, cleaned up heads, and a single plane carb intake. It is consistent as hell, low maintenance, and doesn't leak a drop of oil. We ran it last weekend and several people came over to check it out assuming it was LS powered. They couldn't believe how good it ran with an old JY mag motor.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Junkyard magnum record [Re: n20mstr] #2188621
11/03/16 11:09 AM
11/03/16 11:09 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Impressive for a 52 jet. Congrats!
Info on the rest of the setup? I assume it's not too secret squirrel being that you're posting ETs...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Junkyard magnum record [Re: n20mstr] #2188682
11/03/16 01:11 PM
11/03/16 01:11 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
time slip or didn't happen
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Junkyard magnum record [Re: n20mstr] #2188697
11/03/16 01:47 PM
11/03/16 01:47 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
Watching this closely. My car goes mid 12's at 105ish now.
I'm converting from a motorhome 440 to a low mile 5.9 Mag this winter.
I just planned on swapping to a 380HP crate cam, M1 intake, DT headers and reusing everything else. 825 Mighty Demon, 727, cheetah VB , PTC 3500, 3.91 gears.
Re: Junkyard magnum record [Re: n20mstr] #2189015
11/03/16 09:51 PM
11/03/16 09:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What does it run without that hit on nos?
Re: Junkyard magnum record [Re: cudaman1969] #2189026
11/03/16 10:01 PM
11/03/16 10:01 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Went a 12.14 with -1200 feet air in the spring.
Combo is 3300lb duster, ptc 9" converter. 4.10 gears
Re: Junkyard magnum record [Re: n20mstr] #2189027
11/03/16 10:02 PM
11/03/16 10:02 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I ran a best of 7.27 in the 1/8 with a 360/380 hp crate motor, no NOS at 2950 lbs. That is basically a 2000 360 magnum with a .501/.513 cam with a Mopar M1 intake everything else stock magnum. I think that would be 11.40's in the 1/4.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Junkyard magnum record [Re: D-50] #2189585
11/04/16 06:38 PM
11/04/16 06:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do any porting of the heads? I'm anticipating my build too, same as yours only I did the heads with the plastic porting temps and I'm useing the 1.7 roller rockers and spring kit from Chrysler, can't wait.
Re: Junkyard magnum record [Re: cudaman1969] #2189640
11/04/16 08:57 PM
11/04/16 08:57 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
No porting everything stock except cam and intake, 9/1 compression. No Power Adder...
Re: Junkyard magnum record [Re: n20mstr] #2189815
11/05/16 12:53 AM
11/05/16 12:53 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Excited there is a standing challenge for this. Got my new 69mm turbo kit prototype going on a junkyard '93 318 in a 71 demon to get after this record in the spring.
Re: Junkyard magnum record [Re: n20mstr] #2196000
11/14/16 12:51 AM
11/14/16 12:51 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
10.99 today, still just a .052 nitrous jet !
