Re: Junkyard magnum record
[Re: n20mstr]
#2188404
11/02/16 11:15 PM
11/02/16 11:15 PM
Posts: 4,682 On the parachute mount
n20mstr
4 mods to a stock magnum,
1 nitrous plate with 52n 47 fuel
2 intake with 650 carb
3 Scott brown cam
4 changed pushrods and oil pan
That's it, never took the heads off, reused the lifters and all the stock valvetrain.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2188431
11/02/16 11:40 PM
11/02/16 11:40 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
IMHO they are one of the best bang for the buck options out there. We have one in a 3300 lb Dakota that runs mid 11's with not much at all done to it. I just dingle berry honed it, added a set of std. KB 107s, hughes hyd. roller cam, cleaned up heads, and a single plane carb intake. It is consistent as hell, low maintenance, and doesn't leak a drop of oil. We ran it last weekend and several people came over to check it out assuming it was LS powered. They couldn't believe how good it ran with an old JY mag motor.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: n20mstr]
#2188621
11/03/16 11:09 AM
11/03/16 11:09 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Impressive for a 52 jet. Congrats!
Info on the rest of the setup? I assume it's not too secret squirrel being that you're posting ETs...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: n20mstr]
#2188682
11/03/16 01:11 PM
11/03/16 01:11 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Got a magnum from the junkyard in my sons duster, went 11.22 time slip or didn't happen
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: cudaman1969]
#2189026
11/03/16 10:01 PM
11/03/16 10:01 PM
n20mstr
What does it run without that hit on nos? Went a 12.14 with -1200 feet air in the spring. Combo is 3300lb duster, ptc 9" converter. 4.10 gears
[Re: n20mstr]
#2189027
11/03/16 10:02 PM
11/03/16 10:02 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I ran a best of 7.27 in the 1/8 with a 360/380 hp crate motor, no NOS at 2950 lbs. That is basically a 2000 360 magnum with a .501/.513 cam with a Mopar M1 intake everything else stock magnum. I think that would be 11.40's in the 1/4.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2189585
11/04/16 06:38 PM
11/04/16 06:38 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
I ran a best of 7.27 in the 1/8 with a 360/380 hp crate motor, no NOS at 2950 lbs. That is basically a 2000 360 magnum with a .501/.513 cam with a Mopar M1 intake everything else stock magnum. I think that would be 11.40's in the 1/4. Do any porting of the heads? I'm anticipating my build too, same as yours only I did the heads with the plastic porting temps and I'm useing the 1.7 roller rockers and spring kit from Chrysler, can't wait.
[Re: cudaman1969]
#2189640
11/04/16 08:57 PM
11/04/16 08:57 PM
D-50
North, Alabama
I ran a best of 7.27 in the 1/8 with a 360/380 hp crate motor, no NOS at 2950 lbs. That is basically a 2000 360 magnum with a .501/.513 cam with a Mopar M1 intake everything else stock magnum. I think that would be 11.40's in the 1/4. Do any porting of the heads? I'm anticipating my build too, same as yours only I did the heads with the plastic porting temps and I'm useing the 1.7 roller rockers and spring kit from Chrysler, can't wait. No porting everything stock except cam and intake, 9/1 compression. No Power Adder...
