Wheels...lugnuts...conical seat? Now tires too... #2186275
10/30/16 11:14 PM
10/30/16 11:14 PM
Western Md.
skicker Online tonguue OP
"The Champ"
skicker  Online Tonguue OP
"The Champ"
Western Md.
I'm trying to pick a set of wheels for the 72 Duster Dad's putting together. I can work with a 5.5 b/s 15x10 on the rear and get away with a 29" or so tire.
I have converted to a wilwood disc brake kit on all 4 corners and have 3" studs in the axles and rotors.
Car should be solid low 11's with the 416.
I have found a set of wheels on Summit that will work for what I need and the price is good but they are set up for a 60 degree conical seat.
Any issues with using them? Anyone make a 1/2 conical lug nut that is open end or am I looking at cutting a set?
I just got a bad feeling these may not pass tech if I decided to take it to the track a few times...
Fronts... https://www.summitracing.com/parts/vsw-521h5465p-19/overview/
Rears... https://www.summitracing.com/parts/vsw-521h5165p0/overview/
...FAFO...
Re: Wheels...lugnuts...conical seat? [Re: skicker] #2186312
10/30/16 11:38 PM
10/30/16 11:38 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I'm running 60deg conical lug nuts on my Belvedere. Bought the open end lug nuts at Summit. I believe Gorilla is the brand.
Have had no issues. Car weighs 3940 and has been 11.08 at 121.
Ok
Re: Wheels...lugnuts...conical seat? [Re: skicker] #2186348
10/31/16 12:06 AM
10/31/16 12:06 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Conical seat wheels here. Open lug nuts are no problem to find, and there is no tech issue that I'm aware of with them.
Re: Wheels...lugnuts...conical seat? [Re: StealthWedge67] #2186392
10/31/16 01:04 AM
10/31/16 01:04 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
Thx to you both...I may just have to get them in the mail... boogie
...FAFO...
Re: Wheels...lugnuts...conical seat? [Re: skicker] #2186772
10/31/16 03:30 PM
10/31/16 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: John_Kunkel] #2186880
10/31/16 06:32 PM
10/31/16 06:32 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
I pulled the trigger on the wheels and added these too... https://www.summitracing.com/parts/GOR-45088-20
4 wheels with lugs delivered to the door for less than $500.00 works for me right now... up
Next...tires... runaway
He wants drag radials after having slicks on the 69 Dart and he wants them to have tread.
I want about 28.5-29.5" tall and about 10" wide that are sticky enough to hook hard with a front tire that will have near the same tread and sidewall markings... shruggy
...FAFO...
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: skicker] #2186919
10/31/16 07:37 PM
10/31/16 07:37 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Will you have the clearance for the 29 tires
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: 67mprfan] #2186927
10/31/16 07:48 PM
10/31/16 07:48 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Eldon check out the build thread...I posted a few pics there. Here is one with the almost 30" tall tires from the back of Satellite. 275/60/17 on 9.5 wheels.
Second pic is the 27.5 bias tires on 7" wheels
29's should be OK...29.5 may be pushing it...
...FAFO...
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: skicker] #2186978
10/31/16 08:46 PM
10/31/16 08:46 PM
Puyallup, WA
Puyallup, WA
Sounds like you're talking about a set of 275 drag radials. There are a few out there, I like Mickey T's. Their ET Street S/S Radial sounds like what you're looking for, and although they won't match perfectly, paired with a set of Sportsman S/T's or Sportsman S/R's up front will offer a matched look.
http://www.mickeythompsontires.com/strip.php?item=ETStreetSS
http://www.mickeythompsontires.com/street.php?item=SportsmanST
http://www.mickeythompsontires.com/street.php?item=SportsmanSR
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: skicker] #2187083
10/31/16 10:41 PM
10/31/16 10:41 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'll check out the thread but that 29 does look close especially if you do a burnout
Re: Wheels...lugnuts...conical seat? Now Tires too... [Re: 67mprfan] #2187704
11/01/16 10:34 PM
11/01/16 10:34 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Eldon the pic of the big tire is almost 30".
I ordered the wheels and lug nuts yesterday morning from Summit and they were here today at 3:30... up
I took a rear down and bolted it up...I don't see any issues...If these were available in a 6" b/s I may have went that route but it would be pushing the envelope at the leaf spring.
I like the lug nut design...with the thickness of the wheel they could actually be closed on the end as they stick past the studs about 1/4"...
Thinking about getting a pair of the MT tires...With the 4.56 gear I'm a little hesitant to go as big as a 29" thinking it may want a little more gear at the stripe...Then again this 416 should pull a lot harder than the 340 that's in the Dart... shruggy runaway
...FAFO...
