Eldon the pic of the big tire is almost 30".
I ordered the wheels and lug nuts yesterday morning from Summit and they were here today at 3:30...
I took a rear down and bolted it up...I don't see any issues...If these were available in a 6" b/s I may have went that route but it would be pushing the envelope at the leaf spring.
I like the lug nut design...with the thickness of the wheel they could actually be closed on the end as they stick past the studs about 1/4"...
Thinking about getting a pair of the MT tires...With the 4.56 gear I'm a little hesitant to go as big as a 29" thinking it may want a little more gear at the stripe...Then again this 416 should pull a lot harder than the 340 that's in the Dart...
