Camshaft vs Rotor Position Small Block #2185017
10/29/16 12:04 AM
10/29/16 12:04 AM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Replacing a skipped timing chain on a small block and not understanding something:
With both marks on the cam sprocket and crank sprocket facing each other, the rotor is pointed at #6 shruggy
Wha? Shouldn't it be pointed at #1? To get it to #1 the mark is straight up. Am I doing something wrong?
Mo' Farts
Moderated by "tbagger".
Re: Camshaft vs Rotor Position Small Block [Re: Grizzly] #2185067
10/29/16 01:27 AM
10/29/16 01:27 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
that is correct...cam at 6 o'clock and crank at 12 o'clock...number 6 is firing...
rotate crank once and cam dot will be at 12 noon...number 1 firing...
went installing chain it is easier to eye ball the dots with cam at 6 and crank a 12 noon...
Tony
70 AARCuda Vitamin C
Re: Camshaft vs Rotor Position Small Block [Re: Grizzly] #2185083
10/29/16 01:57 AM
10/29/16 01:57 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Thank-you, Sir! up
Mo' Farts
Re: Camshaft vs Rotor Position Small Block [Re: 70AARcuda] #2185098
10/29/16 02:28 AM
10/29/16 02:28 AM
with it rotated once to get at 12/12 on the dots, then back up the dampener to 15 BTDC then turn dist housing till the magnet is dead even with the tooth that places the rotor under the #1 cap terminal. wouldn't hurt to clock the intergear so at that position the rotor is facing forward & slightly to the pass side which lets the plug wires nestle the neatest with the shortest lengths & maintains OE standardization. Not a dealbreaker by any means tho, just my OCD
