What size are 440 freeze plugs
#2184859
10/28/16 09:08 PM
10/28/16 09:08 PM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
My local auto parts store does not have the freeze plug kit, but they have the plugs individually in bulk. Does 1 5/8" sound right for the block sides?? and 2 9/64" seem right for the rear of the cam journal?? Any input would be appreciated. Thanks, Jeff
Re: What size are 440 freeze plugs
[Re: SlickRS23]
#2184898
10/28/16 09:47 PM
10/28/16 09:47 PM
RapidRobert
(6) 1 & 5/8 and the rear cam plug might be a special one (the shape), a Mopar item and I'm sure it is a different dia. Some freeze plugs, the depth of em is way thinner than others. get the good ones
[Re: SlickRS23]
#2184947
10/28/16 10:54 PM
10/28/16 10:54 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Rock Auto has the 440 kit.. $11.96 brass, $4.73 steel.. http://www.rockauto.com/en/catalog/dodge,1970,charger,7.2l+440cid+v8,1079096,engine,expansion+plug+/+set,5332 Just my $0.02...
[Re: bbtrux]
#2185274
10/29/16 01:44 PM
10/29/16 01:44 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
My local auto parts store got them for me. They are Dorman and they are available as shallow or deep plugs.
[Re: bbtrux]
#2185281
10/29/16 01:52 PM
10/29/16 01:52 PM
RapidRobert
Where do you get all the plugs for the cylinder heads? Havent located those yet. they are 1&1/4 on SB & might be the same on BB & parts house Dormans are fine. I've seen the thin ones & I dont know it they are just cheap or if they are for a non automotive specific app but get the deep ones. EDIT brass (all I had on hand for extras) but the depth is the same
[Re: SlickRS23]
#2185534
10/29/16 09:31 PM
10/29/16 09:31 PM
markz528
Morrow, OH
The deep ones look like they might be easier to get in straight and possibly seal a little better. Thanks for all the replies.
Correct but the deep ones are harder to remove.
[Re: markz528]
#2185540
10/29/16 09:43 PM
10/29/16 09:43 PM
SlickRS23
Chicagoland 'Burbs
Correct but the deep ones are harder to remove. I guess you would have to knock then in further to remove, possibly hitting the cylinder.
