What size are 440 freeze plugs #2184859
10/28/16 08:08 PM
10/28/16 08:08 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
My local auto parts store does not have the freeze plug kit, but they have the plugs individually in bulk.
Does 1 5/8" sound right for the block sides?? and 2 9/64" seem right for the rear of the cam journal??
Any input would be appreciated.
Thanks, Jeff
Re: What size are 440 freeze plugs [Re: SlickRS23] #2184898
10/28/16 08:47 PM
10/28/16 08:47 PM
(6) 1 & 5/8 and the rear cam plug might be a special one (the shape), a Mopar item and I'm sure it is a different dia. Some freeze plugs, the depth of em is way thinner than others. get the good ones
Re: What size are 440 freeze plugs [Re: SlickRS23] #2184947
10/28/16 09:54 PM
10/28/16 09:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Rock Auto has the 440 kit..
$11.96 brass, $4.73 steel..
http://www.rockauto.com/en/catalog/dodge,1970,charger,7.2l+440cid+v8,1079096,engine,expansion+plug+/+set,5332
Just my $0.02... wink
Re: What size are 440 freeze plugs [Re: Sinitro] #2185136
10/29/16 06:28 AM
10/29/16 06:28 AM
IN
ahy Offline
ahy  Offline
IN
Mancini has them as well.
Re: What size are 440 freeze plugs [Re: ahy] #2185222
10/29/16 11:30 AM
10/29/16 11:30 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Where do you get all the plugs for the cylinder heads? Havent located those yet.
Re: What size are 440 freeze plugs [Re: bbtrux] #2185274
10/29/16 12:44 PM
10/29/16 12:44 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My local auto parts store got them for me. They are Dorman and they are available as shallow or deep plugs.
Re: What size are 440 freeze plugs [Re: bbtrux] #2185281
10/29/16 12:52 PM
10/29/16 12:52 PM
they are 1&1/4 on SB & might be the same on BB & parts house Dormans are fine. I've seen the thin ones & I dont know it they are just cheap or if they are for a non automotive specific app but get the deep ones. EDIT brass (all I had on hand for extras) but the depth is the same
Re: What size are 440 freeze plugs [Re: SlickRS23] #2185310
10/29/16 02:00 PM
10/29/16 02:00 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
Well, I got the 1 5/8" and they fit perfect. He also had the deep ones but I got the shallows as they were the same as what was in there originally.
The deep ones look like they might be easier to get in straight and possibly seal a little better.
Thanks for all the replies.
Re: What size are 440 freeze plugs [Re: SlickRS23] #2185534
10/29/16 08:31 PM
10/29/16 08:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Correct but the deep ones are harder to remove.
Re: What size are 440 freeze plugs [Re: markz528] #2185540
10/29/16 08:43 PM
10/29/16 08:43 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
I guess you would have to knock then in further to remove, possibly hitting the cylinder.
Re: What size are 440 freeze plugs [Re: SlickRS23] #2188566
11/03/16 07:23 AM
11/03/16 07:23 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Near as I can tell, on B/RB the cylinder head sides take 1 1/4, and the ends appear to be 1".Please correct me if wrong.
