70 GTX - Air Grabber / Holley Bowl Vent #2184374
10/28/16 09:43 AM
10/28/16 09:43 AM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
I just picked up a 6bbl, air grabber - my car only has a single nipple valve cover breather. So the center car bowl vent has nothing to plug into.
Is this correct? I know there are 3 nipple breathers, but I believe those are for cars with a vent line back to the tank.
So, should my car have a 2 nipple breather or does the center carb vent somewhere else ?
Re: 70 GTX - Air Grabber / Holley Bowl Vent [Re: Mr D21] #2184551
10/28/16 02:52 PM
10/28/16 02:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If your car has N95 then it has the vent line back to the tank, 3 nipple breather and a carb bowl vent.
If it's not a California car then it has a single nipple and there is NO carb bowl vent hookup. The vent goes out the top of the bowl to air.
I'm guessing you most likely have the wrong carb, probably a 4144
Re: 70 GTX - Air Grabber / Holley Bowl Vent [Re: Morty426] #2184557
10/28/16 02:58 PM
10/28/16 02:58 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
wow Morty - you are correct, it is a 41441.
So what is the correct carb? Its an auto car...
Re: 70 GTX - Air Grabber / Holley Bowl Vent [Re: Mr D21] #2184590
10/28/16 03:23 PM
10/28/16 03:23 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
4144 is the CA AT trans carb and Holley used that as the generic replacement for all center carbs - that's why you find so many of them all over the country
What you need is 4376 for a non-CA automatic
Re: 70 GTX - Air Grabber / Holley Bowl Vent [Re: Morty426] #2184600
10/28/16 03:32 PM
10/28/16 03:32 PM
california
Mr D21 Offline OP
Mr D21  Offline OP
california
Thanks again Chris, you are a huge asset to this group !!!
OK - time for a parts wanted ad !!!
Re: 70 GTX - Air Grabber / Holley Bowl Vent [Re: Mr D21] #2184654
10/28/16 04:20 PM
10/28/16 04:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Check your email - I've got two
