Re: NAG1 into an A body?? [Re: Prodart440] #2182422
10/25/16 07:25 PM
10/25/16 07:25 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
Yes, I used the Hotwire setup with the reprogrammed stock computers. It works great.
Re: NAG1 into an A body?? [Re: Joe12459] #2183020
10/26/16 03:16 PM
10/26/16 03:16 PM
dogdays Offline
dogdays  Offline
Do keep in mind that a Hemi is about 100lb lighter than an LA motor.
Yes, the Mustang II front on fabricated rails should be pretty simple and direct, definitely another way to go. Run the new frame rails back to also act as chassis stiffeners.
The NAG1 is a 5-speed transmission with 3.59 First and 0.83 Fifth. It'd be best used with something like a 2.94 or no more than a 3.23 rear. Actually for driving around one might consider a 2.76 rear gear. This has one advantage in that, with lower numerical gears the pinion gets bigger and thus stronger.
My rule of thumb for street car standard transmissions is they need at least 10:1 combined gear ratio to start at a stop sign going uphill. 10 / 3.59 = 2.79. A 2.76 gear would work, too. Cruising speed is next. 235-75-15 tires need 698 revolutions for a mile. The driveshaft at 60 mph is turning 698 rpm. Multiply times the gear ratio to get transmission output shaft speed.
2.76 x 698 = 1928 rpm at 60. 1600 in OD 2134 OD at 80
2.94 x 698 = 2052 rpm at 60, 1703 in OD 2270 OD at 80
698 x 3.23 = 2255 rpm at 60, 1871 in OD 2494 OD at 80
Numbers I could live with.
R.
Re: NAG1 into an A body?? [Re: dogdays] #2183044
10/26/16 03:44 PM
10/26/16 03:44 PM
Joe12459 Offline
Joe12459  Offline
Yup, I run 3.23s in mine, and it is great off the line and good on the highway, too. There's definitely room for something like 2.94 or even numerically lower, if you do a lot of highway driving.
Re: NAG1 into an A body?? [Re: Prodart440] #2183077
10/26/16 04:38 PM
10/26/16 04:38 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
So with my 3.91 gears, I'd be at 2300 RPM at 80 in OD??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: NAG1 into an A body?? [Re: Prodart440] #2183106
10/26/16 05:11 PM
10/26/16 05:11 PM
Joe12459 Offline
Joe12459  Offline
Depending on tire size, you would be around 3000 RPM at 80mph in OD. At 2300 RPM you would be closer to 60 MPH, again depending on tire size.
Re: NAG1 into an A body?? [Re: Joe12459] #2183308
10/26/16 10:04 PM
10/26/16 10:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A NAG1 with 3.91's will be about the equivalent of a 1:1 with 3.23's.
.83:1 OD X 3.91 = 3.245:1 final drive = 79.73 MPH @ 3100 RPM with a 28" tire.
Kevin
Re: NAG1 into an A body?? [Re: Prodart440] #2183441
10/26/16 11:55 PM
10/26/16 11:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Look up a guy named Darious, not sure if that's spelled right, he did the whole swap in a RR but tunnels should be close between the two cars. Had quite a few headaches with that swap, especially the driveshaft hookup. Car Nag has a three wing flange but the Freightliner van uses a four wing so it can move up and down with the slip type u-joint.
Re: NAG1 into an A body?? [Re: cudaman1969] #2183447
10/27/16 12:01 AM
10/27/16 12:01 AM
Joe12459 Offline
Joe12459  Offline
Actually, the car 5.7 NAG1 uses the three bolt flange, the 6.1 and bigger uses the four bolt flange. I had a driveshaft made by The Driveshaft Shop that uses a CV joint in the front with an adapter to bolt to the three bolt flange on the tranny. They will make it to fit either three bolt or four, and the CV joint eliminates the need for a slip yoke, and makes it a lot more forgiving of driveshaft/pinion angles that may not be ideal.
Re: NAG1 into an A body?? [Re: cudaman1969] #2183478
10/27/16 12:31 AM
10/27/16 12:31 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Darius did the swap in a 70 GTX. I'd suspect that the trans tunnel in the B body is bigger than any A body. He did also switch to an RMS setup and cut the torsion bar crossmember and floor to clear the transmission.
Re: NAG1 into an A body?? [Re: DaytonaTurbo] #2183487
10/27/16 12:34 AM
10/27/16 12:34 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Originally Posted By DaytonaTurbo
Originally Posted By dogdays
So, does anyone make a replacement K-member that uses coilovers for the A body?
R.
Or you could cut off the front clip, lay down new frame rails and do a complete mustang ii type front suspension. I bet you'd shed a few pounds.
Originally Posted By stumpy
PATC gives the complete instructions on how to make a three wire A518od trans work in place of a 727.It is a good swap.
He doesn't want to cut and the 518 won't fit under a stock torsion bar crossmember.
If he doesn't want to cut for a 518 trans,I'm betting that front clip is out of the question.
Re: NAG1 into an A body?? [Re: Joe12459] #2183548
10/27/16 02:10 AM
10/27/16 02:10 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How does just a cv joint allow for the rear movement up and down from normal driving? When that rear drops away from the body, that driveshaft has to get longer, the reason for the slip joint in every non-independent suspension.
Re: NAG1 into an A body?? [Re: Prodart440] #2183560
10/27/16 02:46 AM
10/27/16 02:46 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
You are aware that every LX body car has a fixed differential and independent rear suspension, right?
Re: NAG1 into an A body?? [Re: cudaman1969] #2183596
10/27/16 08:54 AM
10/27/16 08:54 AM
Joe12459 Offline
Joe12459  Offline
The high speed CV joint they designed allows for approximately an inch and a half of movement in and out, which acts like a slip joint. I've put over 7000 miles on mine in a little over a year, and it works great. I was a little skeptical at first, but they assured me it would work, and it does.
Re: NAG1 into an A body?? [Re: Joe12459] #2183660
10/27/16 11:25 AM
10/27/16 11:25 AM
moparx Offline
moparx  Offline
do you have a pic or link for that joint ?
beer
Re: NAG1 into an A body?? [Re: Prodart440] #2183671
10/27/16 11:45 AM
10/27/16 11:45 AM
Joe12459 Offline
Joe12459  Offline
I have some pics of my build on Facebook, but I don't think I have a pic specifically of the driveshaft. If you go to www.thedriveshaftshop.com , they have all of the info. I called them and e-mailed them several times before buying it, and they were really good about explaining how it works.
Re: NAG1 into an A body?? [Re: Joe12459] #2183715
10/27/16 12:22 PM
10/27/16 12:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok, sounds good. Sounds like the old trunion joint from the early 60s cars.
Re: NAG1 into an A body?? [Re: Joe12459] #2183806
10/27/16 03:08 PM
10/27/16 03:08 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Your link seems to go to a page that doesn't do anything.
Is this the page you meant to link?
http://www.driveshaftshop.com/
Kevin
Re: NAG1 into an A body?? [Re: Twostick] #2183834
10/27/16 03:41 PM
10/27/16 03:41 PM
dogdays Offline
dogdays  Offline
Yes, I as thinking large car, hence the 235/75/15s.
The beauty of the NAG1 is it has the 4.32:1 (3.59 to 0.83) gear spread. So you don't need to run 3.91s. A 727 with a 3.91 has a first gear overall ratio of 9.58:1. You'd get that same amount of multiplication using the NAG1 and a 2.66 rear gear. Or the deep ratio A-998 with 3.91s = 10.71:1. Similar NAG1 rear gear would be 2.98. Plus the 2.47 OD effective ratio.
It's all just calculation. I know what I'd do if I had the budget and workspace. Unfortunately I have a stash of two-generation-old parts and they have all become obsolete. Anyone want some J heads?
R.
(actually they are so far under the workbench that I doubt I'll ever find them again)
Re: NAG1 into an A body?? [Re: Twostick] #2183872
10/27/16 04:38 PM
10/27/16 04:38 PM
Joe12459 Offline
Joe12459  Offline
Oops, my mistake. Yes, www.driveshaftshop.com. Thanks!
