Anyone use this alternator? #2182223
10/25/16 03:18 PM
10/25/16 03:18 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Hey all,
Looking at this alternator as possible choice for my mainly BB street car.
https://www.dbelectrical.com/products/al...CFckdgQod__cPyQ
Wondering if anyone has used it or any opinions as to how well it might work.
Thanks!
Re: Anyone use this alternator? [Re: Benforsp] #2182332
10/25/16 05:37 PM
10/25/16 05:37 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
better check the voltage, there's a John Deer Tractor thats not that old on my farm at the moment & its 24volt.
Re: Anyone use this alternator? [Re: rebel] #2182442
10/25/16 07:44 PM
10/25/16 07:44 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I checked it out to be sure. It's 12 V, 120 amp CW rotation.
Someone mentioned to me that some units are RPM limited but not sure on this one. Guessing would pull full amps at a relatively low RPM since it was on a tractor.
Re: Anyone use this alternator? [Re: Benforsp] #2182471
10/25/16 08:25 PM
10/25/16 08:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Why are you looking at tractor parts? Is it the price? I'm sure there is something comparable designed for auto use.
Re: Anyone use this alternator? [Re: Benforsp] #2182478
10/25/16 08:30 PM
10/25/16 08:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Appears to be a Denso. Good alternators.
That's a good price for a new alternator.
Kevin
Re: Anyone use this alternator? [Re: Twostick] #2182509
10/25/16 09:07 PM
10/25/16 09:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You will need the correct regulator and wiring. I'd be concerned about overspeeding it, those diesels only spin 2500 rpm. It also has 1/2" wide belts, most cars are 3/8". twocents
Re: Anyone use this alternator? [Re: Benforsp] #2182513
10/25/16 09:12 PM
10/25/16 09:12 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I think it's internally regulated...Good call on the groove width!
Re: Anyone use this alternator? [Re: Dave Hall] #2182522
10/25/16 09:25 PM
10/25/16 09:25 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
IIRC it needs a key on "alt light" signal to excite the regulator. Sorry about not being clear about that. The Dodge Ram trucks in the early 90's had 120 amp alternators that work with the electrical regulator and don't have the pulley issues. I've got one in my A-body. I bought Andy F's bracket kit, but the O.E. ones can be made to work.
Re: Anyone use this alternator? [Re: Dave Hall] #2182523
10/25/16 09:26 PM
10/25/16 09:26 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
It's not so much about price but this is a new unit that I think will do what I want. It's internally regulated 120 amp. I'd love to hear alternative units that have a similiar price point and be able to deliver this amperage in a Denso style package.
Re: Anyone use this alternator? [Re: Skeptic] #2182525
10/25/16 09:28 PM
10/25/16 09:28 PM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
Hey Skeptic,
Good call on the groove width. Looks like the shaft is a 17 mm so wondering if a pulley swap could be done? I will look into the truck units. Seems most recommend a 60 amp unit but not convinced that would be enough. Btw are the truck units denso style?
Re: Anyone use this alternator? [Re: Benforsp] #2182534
10/25/16 09:36 PM
10/25/16 09:36 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Yes, Mine was out of a 91 5.9 diesel 3500 Ram. If you are running EFI/Electric Fans/Fuel pump(s)/ Hi power Stereo/ all the above, then go 120. A 60 amp Denso will do very well- far better than the O.E. dino alternators at idle and still save weight if you aren't loading up on the add-on electrical goodies.
Re: Anyone use this alternator? [Re: Benforsp] #2182548
10/25/16 09:53 PM
10/25/16 09:53 PM
Parts unknown
590 Challenger Offline
Parts unknown
I sell alternators for a living, it's a great choice. I have 140 amp version I could make a one wire if you like. Don't worry about pulley or speed, it's a great all around alternator
Re: Anyone use this alternator? [Re: Benforsp] #2182551
10/25/16 09:57 PM
10/25/16 09:57 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Never used it, but you may want to check out the maximum RPM rating if you can find it. Some alternators have pretty low limits.
I used a rewound CS144 alternator with a heavy duty bridge rectifier. The kind that comes in Escalades etc. It puts out over 120 amps at a low idle. The bracket cost me less than $40. It's significantly bigger than a Denso, but it will spin out over 240 amps at cruising speed.
Re: Anyone use this alternator? [Re: Benforsp] #2182561
10/25/16 10:06 PM
10/25/16 10:06 PM
Parts unknown
Parts unknown
240 amp crusing down the road with a CS144? Only with special stator and then it would have very little low speed output. Smaller bearings and more rotating weight than the Denso. Sorry, CS144 is no where near as good as the Denso he is looking at, and definitely not with RPM
Re: Anyone use this alternator? [Re: Benforsp] #2182758
10/26/16 02:22 AM
10/26/16 02:22 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Whats the cost for a single wire version?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Anyone use this alternator? [Re: Benforsp] #2182772
10/26/16 02:46 AM
10/26/16 02:46 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Benforsp
Hey Skeptic,
I`ve been running the Denso 60 amp for several years and at night is the time where more voltage would keep you in the 14 volt range for acc. As far as daytime, it jumps to 14.5-14.7 and pretty much stays there................ thumbs
Re: Anyone use this alternator? [Re: HOTMOPR] #2182844
10/26/16 10:01 AM
10/26/16 10:01 AM
Parts unknown
Parts unknown
$130
